Disk Usage Linux
ranjitw
Disk Usage Linux
Post by ranjitw »
Hi All,
Currently we are using check_disk for getting the disk space utilization and the output is shown as below :
DISK OK - free space: /tmp 1023 MB (99% inode=99%)
In the above output its showing the free space for a /tmp mount point instead of free space is there a way I get used space ?
Please help in getting the used space instead of free space.
Regards,
Ranjit W
Re: Disk Usage Linux
There are many custom plugins on the Nagios Exchange. You can test a few and see which one is going to work for you. I found one that might do the job for you:
https://exchange.nagios.org/directory/P ... ce/details
Here's a check run from the CLI:
[root@speedking libexec]# ./check_disk_space.sh -w 80 -c 90 -p /
OK; /: total 27.0GB, used 11.9GB (44.1%), free 13.7GB (50.9%) | 'used space'=12767285248B;23181236633;26078891212;0;28976545792 'used space (pct.)'=44.1%;80;90;0;100
Once you find a plugin that you like, and make sure it works from the command line, set up a command and a service in XI and you are good to go. The document below should help you get started:
Let us know if you get stuck on something.
ranjitw
Post by ranjitw »
Thank you , Please close the post.
Regards,
Ranjit W
