Raising a bug ?
iscb2015
Raising a bug ?
Post by iscb2015 »
It is possible for someone that has downloaded the free version of Nagios to raise a bug ?
If so what are the steps to do so ?
How long would it take for the bug to be reviewed and workarounds or fixes provided ?
Ian
hsmith
Agent Smith
Re: Raising a bug ?
Post by hsmith »
iscb2015 wrote:It is possible for someone that has downloaded the free version of Nagios to raise a bug ?
Definitely.
iscb2015 wrote:If so what are the steps to do so ?
Test. Confirm. Test again. Confirm you can reproduce it. :geek: If you can, post the bug and steps to reproduce here.
Nagios Core is open source and available on GitHub. That is the page we use for anything pertaining to core.
iscb2015 wrote:How long would it take for the bug to be reviewed and workarounds or fixes provided ?
It depends on the complexity of the bug. Generally the fixes make it into the next version. If it is something such a a major security issue, naturally you can assume it is going to take priority.
Hope this clears it up for you!
Former Nagios Employee.
me.
