Hos is the really Bright White colour scheme changed ?
Ever since the upgrade I'm getting complaints from our other admins it is really bright, so does it use the standard windows colour scheme or can it be customised separately ?
Very Bright White
Re: Very Bright White
Can you elaborate on this? Are you taking about a particular theme (XI 5 - Modern, XI 2014 or Classic XI)? What is the Nagios XI version that you upgraded from/to?
sure went from 2.7 to V5 and now most screens are very brigte white, under the prior version they were not, dooes V5 use any of it's own settings or those as determined by windows?
Not sure what would cause that. I just put both these side by side and saw no difference, even so far as as to take a screenshot of the whitespace in each and compare them - identical.
Did you have any custom CSS changes that may have been reverted on the upgrade?
I am not aware of any since we migrated from core to XI a few year back, is there a way I could verify this for sure?
Short of restoring from a backup, not really. Most of that would have been overwritten by the upgrade.
I'm pretty sure we didn't, so to move forward how is the colouring scheme setup in V5? how best to change this I guess
Is this what your XI screen looks like?
Former Nagios Employee.
me.
me.
