Raspberry PI Respbian Jesse
Apache2
Nagios 4.1.1
When I look at all the Services I see this error in the Status Column "NSClient - ERROR: Invalid password. "
I checked on each host C:\Program Files\NSClient++\nsclient.ini
; PASSWORD - Password used to authenticate against server
password = xxxxxxxx
Password is the same on all no special characters all lower case characters and numbers no spaces etc.
where on the Nagios Setup do i check?
any command line to run?
Thoughts
Re: NSClient - ERROR: Invalid password.
Check in any of your service definitions that use check_nt. The -s flag is going to be what should have the password following it.
Former Nagios Employee.
me.
me.
Here is example of my Service definitions in my windows.cfg
host_name SERV011
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
host_name SERV011
service_description Uptime
check_command check_nt!UPTIME
Is this what you are talking about?
Thoughts
host_name SERV011
host_name SERV011
Thoughts
Here's information from our documentation. You'll need to modify the check_nt command to use a password. Have you done this already?
If you specified a password in the NSClient++ configuration file on the Windows machine, you'll need to modify the check_nt command definition to include the password. Open the commands.cfg file for editing.
vi /usr/local/nagios/etc/objects/commands.cfg
Change the definition of the check_nt command to include the "-s <PASSWORD>" argument (where PASSWORD is the password you specified on the Windows machine) like this:
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s PASSWORD -v $ARG1$ $ARG2$
Save the file.
That was it
Made this change
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
New
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s mypass -v $ARG1$ $ARG2$
Services are now checking the servers
Problem solved
Thanks again
Made this change
New
Problem solved
Thanks again
You're welcome. I will now close this thread, but feel free to open another if you need more assistance in the future.
