I successfully config AD authentication for users but we are missing the button to add users from LDAP? We are running Nagios XI 2014R2.7 version.
Is this normal or something not right here? If i create manual a user, that user can login using ldap credentials.
AD Authentication button missing?
Re: AD Authentication button missing?
This is interesting. I am noticing the same thing on a fresh 2014 2.7 machine that I spun up..
What version of the component are you using?
Former Nagios Employee.
me.
me.
