Using 5.2.0 :
Trying to change some argument values on memory to bump it up a bit.
So Selecting, Bulk Modification, Change Command & Arg.
was
-t 'mycode' -P 5693 -M memory/virtual/percent -w 80 -c 90
So for ARG1 putting this in:
-t 'mycode' -P 5693 -M memory/virtual/percent -w 90 -c 95
Then I select all the applicable Main Memory services. Click save/apply. However, no changes were made? I go to Services, click on one of these Main Memory ones and its still at the original value?
Bulk Update bug?
- Box293
- Too Basu
Re: Bulk Update bug?
I can reproduce you problem, it has to do with the single quotes.
I've logged a bug report, TASK ID 6741.
Keep an eye on the release notes to see when this problem is fixed.
- Box293
- Too Basu
This will be fixed in the 5.2.1 release.
