Notifications
lance.peterson
Notifications
Post by lance.peterson »
Is there a way I can add 2 users to every notification field without going to the configure button for every service and host?
Re: Notifications
This is very easy to do via the Bulk Modifications Tool that comes with Nagios XI Enterprise edition. To see a comparison between XI Standard and Enterprise editions, check out the link below:
https://www.nagios.com/products/nagios- ... omparison/
jolson
Attack Rabbit
Re: Notifications
Post by jolson »
Certainly. Navigate to 'Config -> Core Config Manager -> Tools -> Bulk Modifications'. Once there, you are able to add either a contact or contactgroup to many hosts/services at a time.
If you don't have the bulk modifications tool available to you, navigate to 'Config -> Core Config Manager -> Hosts -> Select a host -> Alert Settings -> Manage Contacts'. You should be capable of managing your contacts from this screen. You will still need to do them one at a time, but using this method should be faster than running through the configure button for every host.
Twits Blog
