Hi
In order to monitor a private subnet(192.168.0.0) within my network, I had to setup another instance of nagios server.
This Nagios server has second interface to reach the 192 subnet. But now I end up with two nagios servers.
My goal is the have 2nd nagios server send in all the alert status to 1st one. I looked at https://mathias-kettner.de/checkmk_livestatus.html but still not sure if this what I need.
I am looking for advice on how to monitor 192 subnet using one webgui.
Need advice on aggregate remote nagios server message
jdalrymple
- Skynet Drone
Re: Need advice on aggregate remote nagios server message
Nagios can handle that scenario easily. Here is the forum thread I refer people to when that question (frequently) comes up:
https://support.nagios.com/forum/viewto ... HP#p140693
Thanks for the URL pointer. This info is very helpful.
Did you have more (related) questions or are we all set to close this up?
please close this post. I will post other question if I ran into issue when implementing this approach.
