Schedule immediate check throws error message
CBoekhuis
Post by CBoekhuis »
I just noticed the following: If you try to run a "Schedule Immediate Check" using the "Mass Acknowledge" screen you will get an error message "You must specify a comment".
If you select "Schedule Immediate Check" from the dropdown menu, the comment field turns grey (which seems correct to me). It looks like a 'is the comment field filled' check is also applied to the schedule immediate check, while only Acknowledgement and Schedule Downtime use the comment field.
Because of this error, the schedule immediate check can not be used from the mass acknowledge screen.
Nagios XI 5.2.0, manual installation on CentOS 6.7 64b.
Kind Regards,
Hans Blom
Re: Schedule immediate check throws error message
I was able to recreate the issue and filed an internal bug report (TASK ID 6794). Thanks for reporting this issue!
CBoekhuis
Post by CBoekhuis »
No problem! :D
Greetings...Hans
Hans, is it all right if I lock this thread?
CBoekhuis
Post by CBoekhuis »
Ok, you can lock the thread. Thanks again lmiltchev.
