No HOST data graphs
Fred Kroeger
No HOST data graphs
Post by Fred Kroeger »
Just spun up anbrand new NagiosXI 5 R2.0 VM.
Configured the Host Check to use the check_host_alive command.
This is working fine and looking at the advanced tab, it is returning perfdata OK.
Status Information:	OK - 10.200.3.3: rta 0.236ms, lost 0%
Performance Data:	rta=0.236ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.413ms;;;; rtmin=0.178ms;;;;
However there are no Graphs for the Host Data - also there no _HOST_ xml/rrd files either for the hosts (which would explain why there are no graphs!)
Service Checks are creating graphs OK for these hosts.
Any ideas ?
regads... Fred
Re: No HOST data graphs
Fred, run the following commands and post the output:
cat /usr/local/nagios/etc/hosts/<your host>
ll -d /usr/local/nagios/share/perfdata/<your host>
ll /usr/local/nagios/share/perfdata/<your host>
where you substitute <your host> with the actual hostname. Thanks!
Fred Kroeger
Just added another 12 hosts using Bulk Add and none of them are displaying HOST graph details either.
Only the original host "localhost" shows this graph.
I've added hosts today on another Nagios Server, but this was upgraded to XI5 R2.0 and it is displaying the HOST perf data OK
# cat /usr/local/nagios/etc/hosts/XXX.local.cfg
# Host configuration file
# Created by: Nagios Core Config Manager 2.5.0
# Date:       2015-11-02 15:58:00
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
        host_name                       XXX.local
        use                             linux-server
        alias                           XXX:Wintel:
        display_name                    XXX
        address                         10.X.X.X
        hostgroups                      XX-Wintel
        check_command                   check-host-alive!!!!!!!!
        max_check_attempts              5
        check_interval                  5
        retry_interval                  1
        contact_groups                  XXX
        notification_interval           0
        register                        1
# END OF FILE
# ll -d /usr/local/nagios/share/perfdata/XXX.local
drwxrwxr-x 2 nagios nagios 4096 Nov  2 16:28 /usr/local/nagios/share/perfdata/XXX.local
# ll /usr/local/nagios/share/perfdata/XXX.local
total 4900
-rwxrwxr-x 1 nagios nagios  384952 Nov  2 16:26 CPU_Usage_-_Wintel.rrd
-rw-rw-r-- 1 nagios nagios    2247 Nov  2 16:26 CPU_Usage_-_Wintel.xml
-rwxrwxr-x 1 nagios nagios 1534768 Nov  2 16:27 Disk_Usage_-_Application_Disks_-_Wintel.rrd
-rw-rw-r-- 1 nagios nagios    5450 Nov  2 16:27 Disk_Usage_-_Application_Disks_-_Wintel.xml
-rwxrwxr-x 1 nagios nagios  768224 Nov  2 16:28 Disk_Usage_-_System_Disks_-_Wintel.rrd
-rw-rw-r-- 1 nagios nagios    3453 Nov  2 16:28 Disk_Usage_-_System_Disks_-_Wintel.xml
-rwxrwxr-x 1 nagios nagios 2301312 Nov  2 16:28 Memory_Usage_-_Wintel.rrd
-rw-rw-r-- 1 nagios nagios    6311 Nov  2 16:28 Memory_Usage_-_Wintel.xml
I also ran this
# find /usr/local/nagios/share/perfdata -name "*HOST*"
/usr/local/nagios/share/perfdata/localhost/_HOST_.rrd
/usr/local/nagios/share/perfdata/localhost/_HOST_.xml
# cat /usr/local/nagios/etc/hosts/localhost.cfg
# Date:       2015-10-08 18:45:15
define host {
        host_name                       localhost
        use                             linux-server
        alias                           localhost
        address                         127.0.0.1
        register                        1
# END OF FILE
Post by Box293 »
Very strange.
On this host with the issue, can you please increase the logging verbosity and then take a deeper look into the logs. Follow the FAQ entry below to increase the log level of process_perfdata and npcd:
http://support.nagios.com/wiki/index.ph ... leshooting
Wait 15 - 20 minutes and then get a tail of the logs:
tail -250 /usr/local/nagios/var/perfdata.log > /tmp/perfdata.txt
tail -250 /usr/local/nagios/var/npcd.log > /tmp/npcd.txt
Send us a copy of /tmp/perfdata.txt and /tmp/npcd.txt
Don't forget to turn down the log level as per the FAQ when you are done!
Fred Kroeger
Onya Troy! You got me looking in the right area - all good now.
The perfdata.log showed that none of the Host checks were being processed. Quick check of /var/nagiosramdisk/host-perfdata showed that the file was slowly growing and not being moved to the /var/nagiosramdisk/spool/xidpe directory.
Problem was a typo in the Command "process-host-perfdata-file-bulk". Fixed the typo and Host perfdata is now being processed and HOST graphs are being updated.
Many thanks Troy - this can be closed now. Regards... Fred
Post by Box293 »
Excellent, great to hear it was something that was easy enough to track down.
