ERROR: Process name table : No response from remote host
ariarlet
Post by ariarlet »
Hello
a few days ago me such errors appear: "ERROR: Process name table: No response from remote host". I think it is wrong or SNMP network problems. These errors are intermittent last 1 minute and disappear.
Re: ERROR: Process name table : No response from remote host
Can you post any details on which check you are running and how it is configured?
ariarlet
Post by ariarlet »
$USER1$/check_snmp_win_50000.pl -H $HOSTADDRESS$ $ARG1$
ARG1:
 -C VAR --v2c -n 'IBM WebSphere ...'
sometimes the result is:
and other times the result is:
OUTPUT: 1 services active (matching "IBM WebSphere ...") : OK
I believe check_snmp_win_50000.pl is a custom plugin, can you post a link to it?
ariarlet
Post by ariarlet »
sorry i havent any problem
The problem was infrastructure error
hsmith
Agent Smith
Post by hsmith »
I'll go ahead and close this. Let us know if you need anything else!
Former Nagios Employee.
me.
