can not login to Nagios XI GUI
Greeting,
I can't login into the Nagios XI GUI.
It give me the following error messages:
Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
Run the following from the CLI as root to attempt to repair the DB
/usr/local/nagiosxi/scripts/repair_databases.sh
Y
Y
Re: can not login to Nagios XI GUI
Did you run the script that the error is telling you to run?
/usr/local/nagiosxi/scripts/repair_databases.shFormer Nagios Employee.
me.
me.
Yes, I did
Repair complete and there are no errors.
Y
Y
After running the script, you're still unable to logon.. that's pretty unusual.
What version of XI?
Is your MySQL offloaded?
How did you install XI?
What version of XI?
me.
me.
One of the tech support help us with the original installation and upgrade.
Nagios XI 2011R2.4 . We might have a newer version but I don't know how to run and get the version.
[root@nms bin]# ./nrpe v
NRPE - Nagios Remote Plugin Executor
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.15
Last Modified: 09-06-2013
License: GPL v2 with exemptions (-l for more info)
Version: 2.15
Can you show the output from when you run the repair_databases script?
me.
me.
It looks like our support contract expire two months ago.
mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled)
Active: active (running) since Fri 2015-10-30 09:34:14 EDT; 3h 57min ago
Process: 6117 ExecStartPost=/usr/libexec/mariadb-wait-ready $MAINPID (code=exited, status=0/SUCCESS)
Process: 6087 ExecStartPre=/usr/libexec/mariadb-prepare-db-dir %n (code=exited, status=0/SUCCESS)
Main PID: 6115 (mysqld_safe)
CGroup: /system.slice/mariadb.service
ââ6115 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
ââ6273 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid
-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
Oct 30 09:34:12 nms.galco.com mysqld_safe[6115]: 151030 09:34:12 mysqld_safe Logging to '/var/log/mariadb/mariadb.log'.
Oct 30 09:34:12 nms.galco.com mysqld_safe[6115]: 151030 09:34:12 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
Oct 30 09:34:14 nms.galco.com systemd[1]: Started MariaDB database server.
DATABASE: nagios
TABLE:
/var/lib/mysql/nagios /usr/local/nagios/bin
- recovering (with sort) MyISAM-table 'nagios_acknowledgements.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_commenthistory.MYI'
Data records: 2826
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_comments.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_configfiles.MYI'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_configfilevariables.MYI'
Data records: 131
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_conninfo.MYI'
Data records: 1099
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_contact_addresses.MYI'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactgroup_members.MYI'
Data records: 6
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactgroups.MYI'
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contact_notificationcommands.MYI'
Data records: 108
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactnotificationmethods.MYI'
Data records: 13396
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_contactnotifications.MYI'
Data records: 8994
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
Data records: 9
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_contactstatus.MYI'
Data records: 9
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_customvariables.MYI'
Data records: 708
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_customvariablestatus.MYI'
Data records: 708
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with keycache) MyISAM-table 'nagios_dbversion.MYI'
Data records: 1
- recovering (with sort) MyISAM-table 'nagios_downtimehistory.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
Data records: 859
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_externalcommands.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_flappinghistory.MYI'
Data records: 10002
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_hostchecks.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_contactgroups.MYI'
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_contacts.MYI'
Data records: 109
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostdependencies.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalation_contactgroups.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalation_contacts.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostescalations.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostgroup_members.MYI'
Data records: 53
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hostgroups.MYI'
Data records: 5
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_host_parenthosts.MYI'
Data records: 0
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_hosts.MYI'
Data records: 55
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_hoststatus.MYI'
Data records: 55
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
- recovering (with sort) MyISAM-table 'nagios_instances.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_logentries.MYI'
Data records: 113033
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_notifications.MYI'
Data records: 7987
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_objects.MYI'
Data records: 1888
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- recovering (with sort) MyISAM-table 'nagios_processevents.MYI'
Data records: 911
- Fixing index 1
- recovering (with sort) MyISAM-table 'nagios_programstatus.MYI'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_runtimevariables.MYI'
Data records: 18
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_scheduleddowntime.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicechecks.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- recovering (with sort) MyISAM-table 'nagios_service_contactgroups.MYI'
Data records: 8
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_service_contacts.MYI'
Data records: 926
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicedependencies.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalation_contactgroups.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalation_contacts.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_serviceescalations.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicegroup_members.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_servicegroups.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_service_parentservices.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_services.MYI'
Data records: 684
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_servicestatus.MYI'
Data records: 684
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- Fixing index 7
- Fixing index 8
- Fixing index 9
- Fixing index 10
- Fixing index 11
- Fixing index 12
- Fixing index 13
- Fixing index 14
- Fixing index 15
- Fixing index 16
- Fixing index 17
- Fixing index 18
- Fixing index 19
- recovering (with sort) MyISAM-table 'nagios_statehistory.MYI'
Data records: 123327
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_systemcommands.MYI'
Data records: 161144
- Fixing index 1
- Fixing index 2
- Fixing index 3
- recovering (with sort) MyISAM-table 'nagios_timedeventqueue.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- recovering (with sort) MyISAM-table 'nagios_timedevents.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- Fixing index 3
- Fixing index 4
- Fixing index 5
- Fixing index 6
- recovering (with sort) MyISAM-table 'nagios_timeperiods.MYI'
Data records: 12
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'nagios_timeperiod_timeranges.MYI'
Data records: 66
- Fixing index 1
- Fixing index 2
REPAIR COMPLETE
Active: active (running) since Fri 2015-10-30 13:31:23 EDT; 24ms ago
Process: 6167 ExecStartPost=/usr/libexec/mariadb-wait-ready $MAINPID (code=exited, status=0/SUCCESS)
Process: 6128 ExecStartPre=/usr/libexec/mariadb-prepare-db-dir %n (code=exited, status=0/SUCCESS)
Main PID: 6165 (mysqld_safe)
ââ6165 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
ââ6356 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid
Oct 30 13:31:21 nms.galco.com mysqld_safe[6165]: 151030 13:31:21 mysqld_safe Logging to '/var/log/mariadb/mariadb.log'.
Oct 30 13:31:21 nms.galco.com mysqld_safe[6165]: 151030 13:31:21 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
Oct 30 13:31:23 nms.galco.com systemd[1]: Started MariaDB database server.
DATABASE: nagiosql
TABLE:
/var/lib/mysql/nagiosql /usr/local/nagios/bin
- recovering (with sort) MyISAM-table 'tbl_command.MYI'
Data records: 122
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contactgroup.MYI'
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contact.MYI'
Data records: 9
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_contacttemplate.MYI'
--More--(55%)
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_domain.MYI'
Data records: 1
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostdependency.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostescalation.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostextinfo.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hostgroup.MYI'
Data records: 5
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_host.MYI'
--More--(58%)
Data records: 55
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_hosttemplate.MYI'
Data records: 48
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_info.MYI'
Data records: 218
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_lnkContactgroupToContactgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactgroupToContact.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToCommandHost.MYI'
Data records: 2
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToCommandService.MYI'
Data records: 2
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToContactgroup.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToContacttemplate.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContacttemplateToVariabledefinition.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToCommandHost.MYI'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToCommandService.MYI'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToContactgroup.MYI'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToContacttemplate.MYI'
Data records: 3
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkContactToVariabledefinition.MYI'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHost_DH.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHostgroup_DH.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHostgroup_H.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostdependencyToHost_H.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToContactgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToContact.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToHostgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostescalationToHost.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostgroupToHostgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostgroupToHost.MYI'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToContactgroup.MYI'
Data records: 4
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToContact.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHostgroup.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHost.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToHosttemplate.MYI'
Data records: 46
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHosttemplateToVariabledefinition.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToContactgroup.MYI'
Data records: 2
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToContact.MYI'
Data records: 109
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHostgroup.MYI'
Data records: 46
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHost.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToHosttemplate.MYI'
Data records: 55
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkHostToVariabledefinition.MYI'
Data records: 44
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHost_DH.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHostgroup_DH.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHostgroup_H.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToHost_H.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToService_DS.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicedependencyToService_S.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToContactgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToContact.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToHostgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToHost.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceescalationToService.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicegroupToServicegroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicegroupToService.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToContactgroup.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToContact.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToHostgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToHost.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToServicegroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToServicetemplate.MYI'
Data records: 73
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServicetemplateToVariabledefinition.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToContactgroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToContact.MYI'
Data records: 843
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToHostgroup.MYI'
Data records: 1
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToHost.MYI'
Data records: 679
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToServicegroup.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToServicetemplate.MYI'
Data records: 678
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkServiceToVariabledefinition.MYI'
Data records: 662
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_lnkTimeperiodToTimeperiod.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_logbook.MYI'
Data records: 0
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_mainmenu.MYI'
Data records: 7
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_servicedependency.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_serviceescalation.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_serviceextinfo.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_servicegroup.MYI'
Data records: 0
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_service.MYI'
Data records: 679
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_servicetemplate.MYI'
Data records: 75
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_settings.MYI'
Data records: 12
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_submenu.MYI'
Data records: 29
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_timedefinition.MYI'
Data records: 65
- Fixing index 1
- recovering (with sort) MyISAM-table 'tbl_timeperiod.MYI'
Data records: 11
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_user.MYI'
Data records: 2
- Fixing index 1
- Fixing index 2
- recovering (with sort) MyISAM-table 'tbl_variabledefinition.MYI'
Data records: 707
- Fixing index 1
REPAIR COMPLETE
Reason: Please wrap long outputs in [code][/code] tags.
Do you have paid support through us? If you're a paying customer and you do not have access to the customer support forums, please email [email protected]. If you need to open a ticket, and it's bouncing back, you'll also need to contact [email protected].
Edit: it looks like you edited your post. We're unable to provide remote support without a contract. We can continue troubleshooting the issue here though.
How are you doing on disk space on this system?
df -h
df -ihFormer Nagios Employee.
me.
me.
[root@nms bin]# df -ih
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/rhel-root 19M 266K 19M 2% /
devtmpfs 2.0M 403 2.0M 1% /dev
tmpfs 2.0M 78 2.0M 1% /dev/shm
tmpfs 2.0M 501 2.0M 1% /run
tmpfs 2.0M 13 2.0M 1% /sys/fs/cgroup
/dev/sda2 63K 335 63K 1% /boot
/dev/mapper/rhel-var 13M 9.8K 13M 1% /var
/dev/mapper/rhel-apps 188M 94K 188M 1% /apps
jdalrymple
- Skynet Drone
Are maria and postgres even running?
systemctl status postgresql.service
systemctl status mariadb.service
