SERVICE ALERT shows in nagios log sporadically
jagden
Post by jagden »
I am using a command line to push events to a passive Nagios service, for example:
echo "['date +%s'] PROCESS_SERVICE_CHECK_RESULT;myhost;mytstsvc;2;This is an error" > /usr/local/nagios/var/rw/nagios.cmd
When I'm doing that, the status is always updated in Nagios UI and I can see the reason text and state updated fine.
However, in the Nagios log, 99% of the times, I'm not seeing anything when sending this event.
Sometimes I see:
[1446285712] SERVICE ALERT: myhost;mytstsvc;CRITICAL;HARD;3;This is an error
The problem is, that from GUI I cannot this way track older events or notifications for this service if only once in a while it outputs information when getting my passive alarm.
in nagios.cfg:
log_notifications = 1
I can also see notifications and alerts from other "active" services.
Any idea ?
Re: SERVICE ALERT shows in nagios log sporadically
Post by Box293 »
I believe the source of your error is because your command does not end with a new line \n
I think it needs to be:
echo "['date +%s'] PROCESS_SERVICE_CHECK_RESULT;myhost;mytstsvc;2;This is an error\n" > /usr/local/nagios/var/rw/nagios.cmd
jagden
Post by jagden »
Nope, did not help. Same problem.
Post by Box293 »
Ahhh my mistake on that sorry.
In nagios.cfg you need:
log_passive_checks=1
https://assets.nagios.com/downloads/nag ... gmain.html
jagden
Post by jagden »
It is on already.
Post by Box293 »
Lets say the service is currently in an OK state (0).
If you submit a passive with a CRITICAL state (2) and then another one shortly thereafter as CRITICAL again, does it log it both times or only the first time?
The service might need to be defined as volatile is_volatile=1 in the service definition so that it gets logged each time.
The service may also need flapping disabled flap_detection_enabled=0 however I don't think that would affect the logging.
jagden
Post by jagden »
It has already.
Here is how it is defined:
templates.cfg:
name passive-service
active_checks_enabled 0
passive_checks_enabled 1
parallelize_check 1
notifications_enabled 1
event_handler_enabled 1
register 0
is_volatile 1
parallelize_check 1
obsess_over_service 1
check_freshness 0
flap_detection_enabled 0
failure_prediction_enabled 1
process_perf_data 1
retain_status_information 1
check_period 24x7
max_check_attempts 3
normal_check_interval 10
retry_check_interval 2
contact_groups admins
notification_options w,u,c,r
notification_interval 10
notification_period 24x7
services.cfg:
use passive-service
host_name myhost
service_description tst2
check_command check_dummy
#check_command check_nrpe!tst
contact_groups dba-alert-group
contacts monitoring-mobile
retry_check_interval 5
register 1
What version of Core are you running and can you post your full nagios.cfg file?
jagden
Post by jagden »
Nagios Core version: 3.5.0
Here is my full nagios.cfg file:
accept_passive_host_checks=1
additional_freshness_latency=15
admin_email=nagios@localhost
admin_pager=pagenagios@localhost
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
cfg_file=/usr/local/nagios/etc/objects/commands.cfg
cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
cfg_file=/usr/local/nagios/etc/objects/hosts.cfg
cfg_file=/usr/local/nagios/etc/objects/services.cfg
cfg_file=/usr/local/nagios/etc/objects/templates.cfg
cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=1
check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
child_processes_fork_twice=0
command_check_interval=-1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_embedded_perl=0
enable_environment_macros=0
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=300
execute_host_checks=1
execute_service_checks=1
external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
host_perfdata_command=nagios-process-host-perfdata
host_perfdata_file_mode=a
host_perfdata_file_processing_command=nagios-process-host-perfdata-file
host_perfdata_file_processing_interval=86400
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_event_handlers=1
log_external_commands=1
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=0
log_initial_states=0
log_notifications=1
log_rotation_method=d
log_service_retries=0
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
p1_file=/usr/local/nagios/bin/p1.pl
perfdata_timeout=5
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
process_performance_data=0
process_performance_data=1
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=300
service_interleave_factor=s
service_perfdata_command=nagios-process-service-perfdata
service_perfdata_file_mode=a
service_perfdata_file_processing_command=nagios-process-service-perfdata-file
service_perfdata_file_processing_interval=86400
sleep_time=0.25
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/tmp
use_embedded_perl_implicitly=0
use_large_installation_tweaks=1
use_regexp_matching=0
use_retained_program_state=1
use_syslog=0
use_true_regexp_matching=0
jdalrymple
Skynet Drone
Post by jdalrymple »
I loaded your config into a test system (albeit a 4.X system) and it worked perfectly.
I suggest at this point you turn on debugging and see if you can spot anything in the debug.log:
debug_level=-1
debug_verbosity=2
max_debug_file_size=10000000
Just as a point of clarification - do you get ANYTHING in the nagios.log when you submit your command?
