Nagios XI Linux Client Wizard Install Fails
Hi
I've finally had time to install the Nagios XI OVA and start 'playing' with the software but I've hit an config/install error ??
Trying to use the Linux Agent Configuration wizard but it keeps throwing an error -
Nagios Linux Agent Installation Log
DATE: Thu Oct 29 15:53:56 GMT 2015
DISTRO INFO:
CentOS
6.5
x86_64
Repos already configured - exiting.
Prereqs already installed - skipping...
Adding users and groups...
useradd: user 'nagios' already exists
ERROR: User 'nagios' was not created - exiting.
Obviously indicates the user 'nagios' already exists but it actually doesn't .. it's a group that's called nagios (created by the wizard) that does exist.
I've tried deleting the group and restarting the wizard but frustratingly always end up with the same error
Is there a manual way I can create the groups/users ?? or tweak the wizard ??
Gary
DISTRO INFO:
CentOS
6.5
x86_64
Gary
Re: Nagios XI Linux Client Wizard Install Fails
Can you run the following commands on the remote system in a shell as root you are trying to install the Linux Agent on and post the output here?
grep nag /etc/passwd
grep nag /etc/groupBe sure to check out our Knowledgebase for helpful articles and solutions!
Here you go ..
[root@mx-myatrium ~]# grep nag /etc/passwd
[root@mx-myatrium ~]# grep nag /etc/group
nagcmd
503:nagios
nagios
505:
nagcmd
nagios
Here are the instructions for adding the nagios user account and adding it to the groups.
Run the following in a shell as root on the remote system.
Then in the linux-nrpe-agent folder, run the following so the installer script doesn't try and add the nagios user / groups again.
After this, continue in with the installation and let us know if it works for you.
useradd nagios
usermod -a -G nagcmd nagios
usermod -a -G nagios nagios
touch installed.usersgroupsBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi
unfortunately, still fails ...
[root@mx-myatrium ~]# useradd nagios
nagcmd
503:nagios
nagios
505:nagios
Rgds
GaryW
nagcmd
nagios
Rgds
GaryW
Is the machine that you're trying to install the agent on tied into AD/LDAP where you may have a user named Nagios? Shot in the dark, but I've seen things like this before.
Former Nagios Employee.
me.
me.
unfortunately not .. there is no nagios account in AD/LDAP either
What does a userdel -f nagios do?
me.
me.
[root@mx-myatrium ~]# userdel -f nagios
userdel: cannot remove entry 'nagios' from /etc/passwd
Interesting that it says it can't delete it, not that it doesn't exist..
Unlikely, but what's grep -i nag /etc/passwd return?
me.
me.
