Postgres and Backup
wiproltdwiv
Postgres and Backup
Post by wiproltdwiv »
Dear Sir/Madam,
I need your urgent help!!!!!
1) how to monitor postgresql by using nagios.(Please provide any link if possible)
Parameters need to be monitor(provide plugins for the below) :
Database Status
postgreSQL Log file monitoring (pg_log file)
Disk Utilization (%)
ASM Diskgroup used space % - ASM
DR Sync Difference - Dataguard
2) how to monitor postgresql by using nagios.(Please provide any link if possible)
CPU Utilization
Memory Utilization
Storage Pool space utilizaiton
Availability of Scratch Media
Max. num of mount points
Drive Offline
Path Offline
Data backed up
Backup Failed
Backup Missed
:oops:
hsmith
Agent Smith
Re: Postgres and Backup
Post by hsmith »
Have you ran any of the postgres wizards(under the configure menu) that we have built into Nagios XI? Inside of XI we have the following wizards:
Postgres Database:
Connection Status, Database Size, Table Sizes, Relation Sizes, Sequences.
Postgres Query:
Monitor a query of your choosing ran vs. the DB.
Postgres Server:
Connection Status, Backend Connections, WAL file count.
We also have a number of plugins on Nagios Exchange built for Postgres monitoring.
Hopefully this can help.
Former Nagios Employee.
me.
wiproltdwiv
thanks a lot ....
I have another Domain "Storage". How i will add this domain into NagiosXI.
Please find the below parameters which needs to be monitor:
Availability of Storage
SP Performance Charecterstics
Utilization (%)
Queue Length
Response Time (ms)
"Total Bandwidth
(MB/s)"
"Total Throughput
(I/O/sec)"
LUN Performance Charecterstics:
Utilization (%)
Queue Length
Response Time (ms)
"Total Bandwidth
(MB/s)"
"Total Throughput
(I/O/sec)"
DISK Performance Charecterstics:
Utilization (%)
Queue Length
Response Time (ms)
"Total Bandwidth
(MB/s)"
"Total Throughput
(I/O/sec)"
Are these Windows domains? You may be able to use check_disk_smart
