Auto run reports issue
BanditBBS
Post by BanditBBS »
So, I can across an interesting issue today. Was showing someone something dealing with the status history report. I wanted to add to his views and have it rotate, but because auto run reports is off, the report isn't run when that view is cycled in. What do you think, FR, Bug, not sure what to call this.....
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
WillemDH
Re: Auto run reports issue
Post by WillemDH »
Also noticed this. Also sending people links to reports are also not autoran.
Nagios XI 5.8.1
https://outsideit.net
ssax
Dreams In Code
Post by ssax »
That is interesting, let me take a look and see, I think if it's in a view it should autorun.
ssax
Dreams In Code
Post by ssax »
This will have to be architected and implemented in all the reports, I've created a feature request for it since it's technically doing what it's supposed to:
NEW TASK ID 6887 created - Nagios XI Feature Request: Rotating Views - Disable autorun reports should be ignored
