Hello All,
Was wondering if I could create a notification set up for a single check on Nagios Core as follows :
First event
Text Alert to Comm Team + Bill
Emails to Comm Team, NOC + Bill
Subsequent Events
Escalation (after 30 minutes, every 30 minutes)
Emails to Comm Team, NOC , Bill &
IT Support Management
Can this be accomplished within a single check ? The Escalation is a normal escalation but can I set up this single check to send out a text message ONLY for the 1st alert? Or do I create a 2nd instance of the check to only send out the text message 1x and let the orig check do the emails and the escalation?
Steve
Multiple Notifications on a check in Core
Re: Multiple Notifications on a check in Core
Have the service notify via email (edit: to the Comm Team, NOC + Bill) every time. Create one escalation to only occur on the first notification and have it send the text. Create a second escalation to start emailing the IT support management team.
Thanks @eloyd. Does this answer your question @a31modela?
thanks very much, thats exactly what I wanted to do. wasn't sure about the multiple notifications in a single check.
Appreciate both of you chiming in
Thanks again for the quick answer !
Regards,
Steve
Regards,
Steve
Only thank me if it works the way you want.
Glad to see this worked out so quickly! I will now close this thread, but feel free to open another if you ever need more assistance in the future.
