Hi all,
we are trying to create a custom performance report for :CPU - Memory - disks of ALL server in Nagios XI.
This report should be visible in one only report.
If it's not possible we'd like to see them divided in service groups.
Do you have any suggestion?
Thx in advance
Custom report
Re: Custom report
Unfortunately, at this time we do not have a way to create custom reports.
The possibility for service group reporting may work for you. For this, you would need to setup 4 service groups. One service group with the three (CPU/Memory/Disk), one for CPU, one for memory, and one for disk. From there, you can assign the specific services to those, to generate reports.
This will allow you to generate one report on the main service group that includes all three metrics, or generate a report based on just one of the service groups.
Does this help you?
Does this help you?
Re: Custom report
Hi Rkennedy,
thanks for your answer.
I followed your instructions and i obtained the as_is.JPG.
My goal is to have the same of "to_obtain.JPG" but with all the server I have.
At the end I would obtain a report with:
memory cpu disk
server 1
server2
server3
etc
everything in 1 report.
Could you suggest me how to proceed?
memory cpu disk
server 1
server2
server3
etc
Re: Custom report
If I understand correctly, then you will need one service group for each metric you want to monitor. From there, you will need to put all of those in one 'master' service group to make your one report.
Example -
Service group 'cpu-mem-disk', has 3 service groups in it, cpu, memory, and disk.
From there, all services related to cpu are in the CPU service group (which it looks like you've done). You just need additional ones for memory / disk.
After all that, assign your master service group to all three of those sub-service groups (cpu / memory / disk).
Example -
Re: Custom report
You could create a couple of dashboards, i.e. "CPU Usage" and "Memory Usage", add dashlets (cpu & memory graphs) to them, them schedule the page as a report.
Note: You will need to have Nagios XI Enterprise Edition to schedule the report.
Re: Custom report
Hi lmiltchev,
Thanks for your help, is it possible to chenge the pdf generated file name in "report"?
Francesco
Francesco
Re: Custom report
This is not available at this time.
Would it be sufficient to make it the name of the report from the "Report Name:" field with a pdf extension?
Re: Custom report
Yes.
How?
Thank you
Francesco
How?
Thank you
Francesco
Re: Custom report
As of now, it isn't possible. However, I've filed a feature request (ID 7014), and spoken with our developers. It will be in the next release!
Re: Custom report
Hi rkennedy,
waiting for next release.
Thank you
Francesco
Thank you
Francesco
