nrpe agent install on RHEL2.4.9
Hi ,
I need to install nrpe agent on Linux machine. nrpe2.15 installed on it but plugins 2.1.1 not able to install on it
do nagios support RHEL2.4 version?
Re: nrpe agent install on RHEL2.4.9
What is the error message you receive when attempting to install the plugins 2.1.1?
I get below error: full command outputalso attached
fsusage.c: In function `get_fs_usage':
fsusage.c:235: parse error before `struct'
fsusage.c:237: `fsd' undeclared (first use in this function)
fsusage.c:237: (Each undeclared identifier is reported only once
fsusage.c:237: for each function it appears in.)
make[4]: *** [fsusage.o] Error 1
make[4]: Leaving directory `/tmp/nagios-plugins-2.1.1/gl'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/tmp/nagios-plugins-2.1.1/gl'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/tmp/nagios-plugins-2.1.1/gl'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/nagios-plugins-2.1.1'
make: *** [all] Error 2
[root@triserv nagios-plugins-2.1.1]# make
make all-recursive
make[1]: Entering directory `/tmp/nagios-plugins-2.1.1'
Making all in gl
make[2]: Entering directory `/tmp/nagios-plugins-2.1.1/gl'
rm -f alloca.h-t alloca.h && \
{ echo '/* DO NOT EDIT! GENERATED AUTOMATICALLY! */'; \
cat ./alloca.in.h; \
} > alloca.h-t && \
mv -f alloca.h-t alloca.h
/bin/mkdir -p arpa
rm -f arpa/inet.h-t arpa/inet.h && \
sed -e 's|@''GUARD_PREFIX''@|GL|g' \
-e 's|@''INCLUDE_NEXT''@|include_next|g' \
-e 's|@''PRAGMA_SYSTEM_HEADER''@|#pragma GCC system_header|g' \
-e 's|@''PRAGMA_COLUMNS''@||g' \
-e 's|@''HAVE_FEATURES_H''@|1|g' \
-e 's|@''NEXT_ARPA_INET_H''@|<arpa/inet.h>|g' \
-e 's|@''HAVE_ARPA_INET_H''@|1|g' \
-e 's/@''GNULIB_INET_NTOP''@/1/g' \
-e 's/@''GNULIB_INET_PTON''@/0/g' \
-e 's|@''HAVE_DECL_INET_NTOP''@|1|g' \
-e 's|@''HAVE_DECL_INET_PTON''@|1|g' \
-e 's|@''REPLACE_INET_NTOP''@|0|g' \
-e 's|@''REPLACE_INET_PTON''@|0|g' \
-e '/definitions of _GL_FUNCDECL_RPL/r c++defs.h' \
-e '/definition of _GL_ARG_NONNULL/r arg-nonnull.h' \
-e '/definition of _GL_WARN_ON_USE/r warn-on-use.h' \
< ./arpa_inet.in.h; \
} > arpa/inet.h-t && \
mv arpa/inet.h-t arpa/inet.h
rm -f configmake.h-t && \
echo '#define PREFIX "/usr/local/nagios"'; \
echo '#define EXEC_PREFIX "/usr/local/nagios"'; \
echo '#define BINDIR "/usr/local/nagios/bin"'; \
echo '#define SBINDIR "/usr/local/nagios/sbin"'; \
echo '#define LIBEXECDIR "/usr/local/nagios/libexec"'; \
echo '#define DATAROOTDIR "/usr/local/nagios/share"'; \
echo '#define DATADIR "/usr/local/nagios/share"'; \
echo '#define SYSCONFDIR "/usr/local/nagios/etc"'; \
echo '#define SHAREDSTATEDIR "/usr/local/nagios/com"'; \
echo '#define LOCALSTATEDIR "/usr/local/nagios/var"'; \
echo '#define INCLUDEDIR "/usr/local/nagios/include"'; \
echo '#define OLDINCLUDEDIR "/usr/include"'; \
echo '#define DOCDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define INFODIR "/usr/local/nagios/share/info"'; \
echo '#define HTMLDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define DVIDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define PDFDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define PSDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define LIBDIR "/usr/local/nagios/lib"'; \
echo '#define LISPDIR "/usr/local/nagios/share/emacs/site-lisp"'; \
echo '#define LOCALEDIR "/usr/local/nagios/share/locale"'; \
echo '#define MANDIR "/usr/local/nagios/share/man"'; \
echo '#define MANEXT ""'; \
echo '#define PKGDATADIR "/usr/local/nagios/share/nagios-plugins"'; \
echo '#define PKGINCLUDEDIR "/usr/local/nagios/include/nagios-plugins"'; \
echo '#define PKGLIBDIR "/usr/local/nagios/lib/nagios-plugins"'; \
echo '#define PKGLIBEXECDIR "/usr/local/nagios/libexec/nagios-plugins"'; \
} | sed '/""/d' > configmake.h-t && \
mv -f configmake.h-t configmake.h
rm -f errno.h-t errno.h && \
{ echo '/* DO NOT EDIT! GENERATED AUTOMATICALLY! */' && \
-e 's|@''NEXT_ERRNO_H''@|<errno.h>|g' \
-e 's|@''EMULTIHOP_HIDDEN''@|0|g' \
-e 's|@''EMULTIHOP_VALUE''@||g' \
-e 's|@''ENOLINK_HIDDEN''@|0|g' \
-e 's|@''ENOLINK_VALUE''@||g' \
-e 's|@''EOVERFLOW_HIDDEN''@|0|g' \
-e 's|@''EOVERFLOW_VALUE''@||g' \
< ./errno.in.h; \
} > errno.h-t && \
mv errno.h-t errno.h
rm -f getopt.h-t getopt.h && \
-e 's|@''HAVE_GETOPT_H''@|1|g' \
-e 's|@''NEXT_GETOPT_H''@|<getopt.h>|g' \
< ./getopt.in.h; \
} > getopt.h-t && \
mv -f getopt.h-t getopt.h
rm -f langinfo.h-t langinfo.h && \
-e 's|@''HAVE_LANGINFO_H''@|1|g' \
-e 's|@''NEXT_LANGINFO_H''@|<langinfo.h>|g' \
-e 's/@''GNULIB_NL_LANGINFO''@/1/g' \
-e 's|@''HAVE_LANGINFO_CODESET''@|1|g' \
-e 's|@''HAVE_LANGINFO_T_FMT_AMPM''@|1|g' \
-e 's|@''HAVE_LANGINFO_ERA''@|1|g' \
-e 's|@''HAVE_LANGINFO_YESEXPR''@|1|g' \
-e 's|@''HAVE_NL_LANGINFO''@|1|g' \
-e 's|@''REPLACE_NL_LANGINFO''@|0|g' \
< ./langinfo.in.h; \
} > langinfo.h-t && \
mv langinfo.h-t langinfo.h
rm -f locale.h-t locale.h && \
-e 's|@''NEXT_LOCALE_H''@|<locale.h>|g' \
-e 's/@''GNULIB_LOCALECONV''@/1/g' \
-e 's/@''GNULIB_SETLOCALE''@/0/g' \
-e 's/@''GNULIB_DUPLOCALE''@/0/g' \
-e 's|@''HAVE_DUPLOCALE''@|1|g' \
-e 's|@''HAVE_XLOCALE_H''@|1|g' \
-e 's|@''REPLACE_LOCALECONV''@|0|g' \
-e 's|@''REPLACE_SETLOCALE''@|0|g' \
-e 's|@''REPLACE_DUPLOCALE''@|0|g' \
-e 's|@''REPLACE_STRUCT_LCONV''@|0|g' \
< ./locale.in.h; \
} > locale.h-t && \
mv locale.h-t locale.h
rm -f math.h-t math.h && \
-e 's|@''INCLUDE_NEXT_AS_FIRST_DIRECTIVE''@|include_next|g' \
-e 's|@''NEXT_AS_FIRST_DIRECTIVE_MATH_H''@|<math.h>|g' \
-e 's/@''GNULIB_ACOSF''@/0/g' \
-e 's/@''GNULIB_ACOSL''@/0/g' \
-e 's/@''GNULIB_ASINF''@/0/g' \
-e 's/@''GNULIB_ASINL''@/0/g' \
-e 's/@''GNULIB_ATANF''@/0/g' \
-e 's/@''GNULIB_ATANL''@/0/g' \
-e 's/@''GNULIB_ATAN2F''@/0/g' \
-e 's/@''GNULIB_CBRT''@/0/g' \
-e 's/@''GNULIB_CBRTF''@/0/g' \
-e 's/@''GNULIB_CBRTL''@/0/g' \
-e 's/@''GNULIB_CEIL''@/0/g' \
-e 's/@''GNULIB_CEILF''@/0/g' \
-e 's/@''GNULIB_CEILL''@/0/g' \
-e 's/@''GNULIB_COPYSIGN''@/0/g' \
-e 's/@''GNULIB_COPYSIGNF''@/0/g' \
-e 's/@''GNULIB_COPYSIGNL''@/0/g' \
-e 's/@''GNULIB_COSF''@/0/g' \
-e 's/@''GNULIB_COSL''@/0/g' \
-e 's/@''GNULIB_COSHF''@/0/g' \
-e 's/@''GNULIB_EXPF''@/0/g' \
-e 's/@''GNULIB_EXPL''@/0/g' \
-e 's/@''GNULIB_EXP2''@/0/g' \
-e 's/@''GNULIB_EXP2F''@/0/g' \
-e 's/@''GNULIB_EXP2L''@/0/g' \
-e 's/@''GNULIB_EXPM1''@/0/g' \
-e 's/@''GNULIB_EXPM1F''@/0/g' \
-e 's/@''GNULIB_EXPM1L''@/0/g' \
-e 's/@''GNULIB_FABSF''@/0/g' \
-e 's/@''GNULIB_FABSL''@/0/g' \
-e 's/@''GNULIB_FLOOR''@/0/g' \
-e 's/@''GNULIB_FLOORF''@/1/g' \
-e 's/@''GNULIB_FLOORL''@/0/g' \
-e 's/@''GNULIB_FMA''@/0/g' \
-e 's/@''GNULIB_FMAF''@/0/g' \
-e 's/@''GNULIB_FMAL''@/0/g' \
-e 's/@''GNULIB_FMOD''@/0/g' \
-e 's/@''GNULIB_FMODF''@/0/g' \
-e 's/@''GNULIB_FMODL''@/0/g' \
-e 's/@''GNULIB_FREXPF''@/0/g' \
-e 's/@''GNULIB_FREXP''@/0/g' \
-e 's/@''GNULIB_FREXPL''@/0/g' \
-e 's/@''GNULIB_HYPOT''@/0/g' \
-e 's/@''GNULIB_HYPOTF''@/0/g' \
-e 's/@''GNULIB_HYPOTL''@/0/g' \
< ./math.in.h | \
sed -e 's/@''GNULIB_ILOGB''@/0/g' \
-e 's/@''GNULIB_ILOGBF''@/0/g' \
-e 's/@''GNULIB_ILOGBL''@/0/g' \
-e 's/@''GNULIB_ISFINITE''@/0/g' \
-e 's/@''GNULIB_ISINF''@/0/g' \
-e 's/@''GNULIB_ISNAN''@/0/g' \
-e 's/@''GNULIB_ISNANF''@/0/g' \
-e 's/@''GNULIB_ISNAND''@/0/g' \
-e 's/@''GNULIB_ISNANL''@/0/g' \
-e 's/@''GNULIB_LDEXPF''@/0/g' \
-e 's/@''GNULIB_LDEXPL''@/0/g' \
-e 's/@''GNULIB_LOG''@/0/g' \
-e 's/@''GNULIB_LOGF''@/0/g' \
-e 's/@''GNULIB_LOGL''@/0/g' \
-e 's/@''GNULIB_LOG10''@/0/g' \
-e 's/@''GNULIB_LOG10F''@/0/g' \
-e 's/@''GNULIB_LOG10L''@/0/g' \
-e 's/@''GNULIB_LOG1P''@/0/g' \
-e 's/@''GNULIB_LOG1PF''@/0/g' \
-e 's/@''GNULIB_LOG1PL''@/0/g' \
-e 's/@''GNULIB_LOG2''@/0/g' \
-e 's/@''GNULIB_LOG2F''@/0/g' \
-e 's/@''GNULIB_LOG2L''@/0/g' \
-e 's/@''GNULIB_LOGB''@/0/g' \
-e 's/@''GNULIB_LOGBF''@/0/g' \
-e 's/@''GNULIB_LOGBL''@/0/g' \
-e 's/@''GNULIB_MODF''@/0/g' \
-e 's/@''GNULIB_MODFF''@/0/g' \
-e 's/@''GNULIB_MODFL''@/0/g' \
-e 's/@''GNULIB_POWF''@/0/g' \
-e 's/@''GNULIB_REMAINDER''@/0/g' \
-e 's/@''GNULIB_REMAINDERF''@/0/g' \
-e 's/@''GNULIB_REMAINDERL''@/0/g' \
-e 's/@''GNULIB_RINT''@/0/g' \
-e 's/@''GNULIB_RINTF''@/0/g' \
-e 's/@''GNULIB_RINTL''@/0/g' \
-e 's/@''GNULIB_ROUND''@/0/g' \
-e 's/@''GNULIB_ROUNDF''@/0/g' \
-e 's/@''GNULIB_ROUNDL''@/0/g' \
-e 's/@''GNULIB_SIGNBIT''@/0/g' \
-e 's/@''GNULIB_SINF''@/0/g' \
-e 's/@''GNULIB_SINL''@/0/g' \
-e 's/@''GNULIB_SINHF''@/0/g' \
-e 's/@''GNULIB_SQRTF''@/0/g' \
-e 's/@''GNULIB_SQRTL''@/0/g' \
-e 's/@''GNULIB_TANF''@/0/g' \
-e 's/@''GNULIB_TANL''@/0/g' \
-e 's/@''GNULIB_TANHF''@/0/g' \
-e 's/@''GNULIB_TRUNC''@/0/g' \
-e 's/@''GNULIB_TRUNCF''@/0/g' \
-e 's/@''GNULIB_TRUNCL''@/0/g' \
sed -e 's|@''HAVE_ACOSF''@|1|g' \
-e 's|@''HAVE_ACOSL''@|1|g' \
-e 's|@''HAVE_ASINF''@|1|g' \
-e 's|@''HAVE_ASINL''@|1|g' \
-e 's|@''HAVE_ATANF''@|1|g' \
-e 's|@''HAVE_ATANL''@|1|g' \
-e 's|@''HAVE_ATAN2F''@|1|g' \
-e 's|@''HAVE_CBRT''@|1|g' \
-e 's|@''HAVE_CBRTF''@|1|g' \
-e 's|@''HAVE_CBRTL''@|1|g' \
-e 's|@''HAVE_COPYSIGN''@|1|g' \
-e 's|@''HAVE_COPYSIGNL''@|1|g' \
-e 's|@''HAVE_COSF''@|1|g' \
-e 's|@''HAVE_COSL''@|1|g' \
-e 's|@''HAVE_COSHF''@|1|g' \
-e 's|@''HAVE_EXPF''@|1|g' \
-e 's|@''HAVE_EXPL''@|1|g' \
-e 's|@''HAVE_EXPM1''@|1|g' \
-e 's|@''HAVE_EXPM1F''@|1|g' \
-e 's|@''HAVE_FABSF''@|1|g' \
-e 's|@''HAVE_FABSL''@|1|g' \
-e 's|@''HAVE_FMA''@|1|g' \
-e 's|@''HAVE_FMAF''@|1|g' \
-e 's|@''HAVE_FMAL''@|1|g' \
-e 's|@''HAVE_FMODF''@|1|g' \
-e 's|@''HAVE_FMODL''@|1|g' \
-e 's|@''HAVE_FREXPF''@|1|g' \
-e 's|@''HAVE_HYPOTF''@|1|g' \
-e 's|@''HAVE_HYPOTL''@|1|g' \
-e 's|@''HAVE_ILOGB''@|1|g' \
-e 's|@''HAVE_ILOGBF''@|1|g' \
-e 's|@''HAVE_ILOGBL''@|1|g' \
-e 's|@''HAVE_ISNANF''@|1|g' \
-e 's|@''HAVE_ISNAND''@|1|g' \
-e 's|@''HAVE_ISNANL''@|1|g' \
-e 's|@''HAVE_LDEXPF''@|1|g' \
-e 's|@''HAVE_LOGF''@|1|g' \
-e 's|@''HAVE_LOGL''@|1|g' \
-e 's|@''HAVE_LOG10F''@|1|g' \
-e 's|@''HAVE_LOG10L''@|1|g' \
-e 's|@''HAVE_LOG1P''@|1|g' \
-e 's|@''HAVE_LOG1PF''@|1|g' \
-e 's|@''HAVE_LOG1PL''@|1|g' \
-e 's|@''HAVE_LOGBF''@|1|g' \
-e 's|@''HAVE_LOGBL''@|1|g' \
-e 's|@''HAVE_MODFF''@|1|g' \
-e 's|@''HAVE_MODFL''@|1|g' \
-e 's|@''HAVE_POWF''@|1|g' \
-e 's|@''HAVE_REMAINDER''@|1|g' \
-e 's|@''HAVE_REMAINDERF''@|1|g' \
-e 's|@''HAVE_RINT''@|1|g' \
-e 's|@''HAVE_RINTL''@|1|g' \
-e 's|@''HAVE_SINF''@|1|g' \
-e 's|@''HAVE_SINL''@|1|g' \
-e 's|@''HAVE_SINHF''@|1|g' \
-e 's|@''HAVE_SQRTF''@|1|g' \
-e 's|@''HAVE_SQRTL''@|1|g' \
-e 's|@''HAVE_TANF''@|1|g' \
-e 's|@''HAVE_TANL''@|1|g' \
-e 's|@''HAVE_TANHF''@|1|g' \
-e 's|@''HAVE_DECL_ACOSL''@|1|g' \
-e 's|@''HAVE_DECL_ASINL''@|1|g' \
-e 's|@''HAVE_DECL_ATANL''@|1|g' \
-e 's|@''HAVE_DECL_CBRTF''@|1|g' \
-e 's|@''HAVE_DECL_CBRTL''@|1|g' \
-e 's|@''HAVE_DECL_CEILF''@|1|g' \
-e 's|@''HAVE_DECL_CEILL''@|1|g' \
-e 's|@''HAVE_DECL_COPYSIGNF''@|1|g' \
-e 's|@''HAVE_DECL_COSL''@|1|g' \
-e 's|@''HAVE_DECL_EXPL''@|1|g' \
-e 's|@''HAVE_DECL_EXP2''@|1|g' \
-e 's|@''HAVE_DECL_EXP2F''@|1|g' \
-e 's|@''HAVE_DECL_EXP2L''@|1|g' \
-e 's|@''HAVE_DECL_EXPM1L''@|1|g' \
-e 's|@''HAVE_DECL_FLOORF''@|1|g' \
-e 's|@''HAVE_DECL_FLOORL''@|1|g' \
-e 's|@''HAVE_DECL_FREXPL''@|1|g' \
-e 's|@''HAVE_DECL_LDEXPL''@|1|g' \
-e 's|@''HAVE_DECL_LOGL''@|1|g' \
-e 's|@''HAVE_DECL_LOG10L''@|1|g' \
-e 's|@''HAVE_DECL_LOG2''@|1|g' \
-e 's|@''HAVE_DECL_LOG2F''@|1|g' \
-e 's|@''HAVE_DECL_LOG2L''@|1|g' \
-e 's|@''HAVE_DECL_LOGB''@|1|g' \
-e 's|@''HAVE_DECL_REMAINDER''@|1|g' \
-e 's|@''HAVE_DECL_REMAINDERL''@|1|g' \
-e 's|@''HAVE_DECL_RINTF''@|1|g' \
-e 's|@''HAVE_DECL_ROUND''@|1|g' \
-e 's|@''HAVE_DECL_ROUNDF''@|1|g' \
-e 's|@''HAVE_DECL_ROUNDL''@|1|g' \
-e 's|@''HAVE_DECL_SINL''@|1|g' \
-e 's|@''HAVE_DECL_SQRTL''@|1|g' \
-e 's|@''HAVE_DECL_TANL''@|1|g' \
-e 's|@''HAVE_DECL_TRUNC''@|1|g' \
-e 's|@''HAVE_DECL_TRUNCF''@|1|g' \
-e 's|@''HAVE_DECL_TRUNCL''@|1|g' \
sed -e 's|@''REPLACE_CBRTF''@|0|g' \
-e 's|@''REPLACE_CBRTL''@|0|g' \
-e 's|@''REPLACE_CEIL''@|0|g' \
-e 's|@''REPLACE_CEILF''@|0|g' \
-e 's|@''REPLACE_CEILL''@|0|g' \
-e 's|@''REPLACE_EXPM1''@|0|g' \
-e 's|@''REPLACE_EXPM1F''@|0|g' \
-e 's|@''REPLACE_EXP2''@|0|g' \
-e 's|@''REPLACE_EXP2L''@|0|g' \
-e 's|@''REPLACE_FABSL''@|0|g' \
-e 's|@''REPLACE_FLOOR''@|0|g' \
-e 's|@''REPLACE_FLOORF''@|0|g' \
-e 's|@''REPLACE_FLOORL''@|0|g' \
-e 's|@''REPLACE_FMA''@|0|g' \
-e 's|@''REPLACE_FMAF''@|0|g' \
-e 's|@''REPLACE_FMAL''@|0|g' \
-e 's|@''REPLACE_FMOD''@|0|g' \
-e 's|@''REPLACE_FMODF''@|0|g' \
-e 's|@''REPLACE_FMODL''@|0|g' \
-e 's|@''REPLACE_FREXPF''@|0|g' \
-e 's|@''REPLACE_FREXP''@|0|g' \
-e 's|@''REPLACE_FREXPL''@|0|g' \
-e 's|@''REPLACE_HUGE_VAL''@|0|g' \
-e 's|@''REPLACE_HYPOT''@|0|g' \
-e 's|@''REPLACE_HYPOTF''@|0|g' \
-e 's|@''REPLACE_HYPOTL''@|0|g' \
-e 's|@''REPLACE_ILOGB''@|0|g' \
-e 's|@''REPLACE_ILOGBF''@|0|g' \
-e 's|@''REPLACE_ISFINITE''@|0|g' \
-e 's|@''REPLACE_ISINF''@|0|g' \
-e 's|@''REPLACE_ISNAN''@|0|g' \
-e 's|@''REPLACE_ITOLD''@|0|g' \
-e 's|@''REPLACE_LDEXPL''@|0|g' \
-e 's|@''REPLACE_LOG''@|0|g' \
-e 's|@''REPLACE_LOGF''@|0|g' \
-e 's|@''REPLACE_LOGL''@|0|g' \
-e 's|@''REPLACE_LOG10''@|0|g' \
-e 's|@''REPLACE_LOG10F''@|0|g' \
-e 's|@''REPLACE_LOG10L''@|0|g' \
-e 's|@''REPLACE_LOG1P''@|0|g' \
-e 's|@''REPLACE_LOG1PF''@|0|g' \
-e 's|@''REPLACE_LOG1PL''@|0|g' \
-e 's|@''REPLACE_LOG2''@|0|g' \
-e 's|@''REPLACE_LOG2F''@|0|g' \
-e 's|@''REPLACE_LOG2L''@|0|g' \
-e 's|@''REPLACE_LOGB''@|0|g' \
-e 's|@''REPLACE_LOGBF''@|0|g' \
-e 's|@''REPLACE_LOGBL''@|0|g' \
-e 's|@''REPLACE_MODF''@|0|g' \
-e 's|@''REPLACE_MODFF''@|0|g' \
-e 's|@''REPLACE_MODFL''@|0|g' \
-e 's|@''REPLACE_NAN''@|0|g' \
-e 's|@''REPLACE_REMAINDER''@|0|g' \
-e 's|@''REPLACE_REMAINDERF''@|0|g' \
-e 's|@''REPLACE_REMAINDERL''@|0|g' \
-e 's|@''REPLACE_ROUND''@|0|g' \
-e 's|@''REPLACE_ROUNDF''@|0|g' \
-e 's|@''REPLACE_ROUNDL''@|0|g' \
-e 's|@''REPLACE_SIGNBIT''@|0|g' \
-e 's|@''REPLACE_SIGNBIT_USING_GCC''@|0|g' \
-e 's|@''REPLACE_SQRTL''@|0|g' \
-e 's|@''REPLACE_TRUNC''@|0|g' \
-e 's|@''REPLACE_TRUNCF''@|0|g' \
-e 's|@''REPLACE_TRUNCL''@|0|g' \
-e '/definition of _GL_WARN_ON_USE/r warn-on-use.h'; \
} > math.h-t && \
mv math.h-t math.h
rm -f netdb.h-t netdb.h && \
-e 's|@''NEXT_NETDB_H''@|<netdb.h>|g' \
-e 's|@''HAVE_NETDB_H''@|1|g' \
-e 's/@''GNULIB_GETADDRINFO''@/1/g' \
-e 's|@''HAVE_STRUCT_ADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_FREEADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_GAI_STRERROR''@|1|g' \
-e 's|@''HAVE_DECL_GETADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_GETNAMEINFO''@|1|g' \
-e 's|@''REPLACE_GAI_STRERROR''@|0|g' \
< ./netdb.in.h; \
} > netdb.h-t && \
mv netdb.h-t netdb.h
rm -f stdalign.h-t stdalign.h && \
cat ./stdalign.in.h; \
} > stdalign.h-t && \
mv stdalign.h-t stdalign.h
rm -f stdbool.h-t stdbool.h && \
sed -e 's/@''HAVE__BOOL''@/0/g' < ./stdbool.in.h; \
} > stdbool.h-t && \
mv stdbool.h-t stdbool.h
rm -f stdint.h-t stdint.h && \
-e 's/@''HAVE_STDINT_H''@/1/g' \
-e 's|@''NEXT_STDINT_H''@|<stdint.h>|g' \
-e 's/@''HAVE_SYS_TYPES_H''@/1/g' \
-e 's/@''HAVE_INTTYPES_H''@/1/g' \
-e 's/@''HAVE_SYS_INTTYPES_H''@/0/g' \
-e 's/@''HAVE_SYS_BITYPES_H''@/1/g' \
-e 's/@''HAVE_WCHAR_H''@/1/g' \
-e 's/@''HAVE_LONG_LONG_INT''@/1/g' \
-e 's/@''HAVE_UNSIGNED_LONG_LONG_INT''@/1/g' \
-e 's/@''APPLE_UNIVERSAL_BUILD''@/0/g' \
-e 's/@''BITSIZEOF_PTRDIFF_T''@/32/g' \
-e 's/@''PTRDIFF_T_SUFFIX''@//g' \
-e 's/@''BITSIZEOF_SIG_ATOMIC_T''@/32/g' \
-e 's/@''HAVE_SIGNED_SIG_ATOMIC_T''@/1/g' \
-e 's/@''SIG_ATOMIC_T_SUFFIX''@//g' \
-e 's/@''BITSIZEOF_SIZE_T''@/32/g' \
-e 's/@''SIZE_T_SUFFIX''@/u/g' \
-e 's/@''BITSIZEOF_WCHAR_T''@/32/g' \
-e 's/@''HAVE_SIGNED_WCHAR_T''@/1/g' \
-e 's/@''WCHAR_T_SUFFIX''@/l/g' \
-e 's/@''BITSIZEOF_WINT_T''@/32/g' \
-e 's/@''HAVE_SIGNED_WINT_T''@/0/g' \
-e 's/@''WINT_T_SUFFIX''@/u/g' \
< ./stdint.in.h; \
} > stdint.h-t && \
mv stdint.h-t stdint.h
rm -f stdio.h-t stdio.h && \
-e 's|@''NEXT_STDIO_H''@|<stdio.h>|g' \
-e 's/@''GNULIB_DPRINTF''@/0/g' \
-e 's/@''GNULIB_FCLOSE''@/0/g' \
-e 's/@''GNULIB_FDOPEN''@/0/g' \
-e 's/@''GNULIB_FFLUSH''@/0/g' \
-e 's/@''GNULIB_FGETC''@/1/g' \
-e 's/@''GNULIB_FGETS''@/1/g' \
-e 's/@''GNULIB_FOPEN''@/0/g' \
-e 's/@''GNULIB_FPRINTF''@/1/g' \
-e 's/@''GNULIB_FPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_FPURGE''@/0/g' \
-e 's/@''GNULIB_FPUTC''@/1/g' \
-e 's/@''GNULIB_FPUTS''@/1/g' \
-e 's/@''GNULIB_FREAD''@/1/g' \
-e 's/@''GNULIB_FREOPEN''@/0/g' \
-e 's/@''GNULIB_FSCANF''@/1/g' \
-e 's/@''GNULIB_FSEEK''@/0/g' \
-e 's/@''GNULIB_FSEEKO''@/0/g' \
-e 's/@''GNULIB_FTELL''@/0/g' \
-e 's/@''GNULIB_FTELLO''@/0/g' \
-e 's/@''GNULIB_FWRITE''@/1/g' \
-e 's/@''GNULIB_GETC''@/1/g' \
-e 's/@''GNULIB_GETCHAR''@/1/g' \
-e 's/@''GNULIB_GETDELIM''@/0/g' \
-e 's/@''GNULIB_GETLINE''@/0/g' \
-e 's/@''GNULIB_OBSTACK_PRINTF''@/0/g' \
-e 's/@''GNULIB_OBSTACK_PRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_PCLOSE''@/0/g' \
-e 's/@''GNULIB_PERROR''@/0/g' \
-e 's/@''GNULIB_POPEN''@/0/g' \
-e 's/@''GNULIB_PRINTF''@/1/g' \
-e 's/@''GNULIB_PRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_PUTC''@/1/g' \
-e 's/@''GNULIB_PUTCHAR''@/1/g' \
-e 's/@''GNULIB_PUTS''@/1/g' \
-e 's/@''GNULIB_REMOVE''@/0/g' \
-e 's/@''GNULIB_RENAME''@/0/g' \
-e 's/@''GNULIB_RENAMEAT''@/0/g' \
-e 's/@''GNULIB_SCANF''@/1/g' \
-e 's/@''GNULIB_SNPRINTF''@/1/g' \
-e 's/@''GNULIB_SPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_STDIO_H_NONBLOCKING''@/0/g' \
-e 's/@''GNULIB_STDIO_H_SIGPIPE''@/0/g' \
-e 's/@''GNULIB_TMPFILE''@/0/g' \
-e 's/@''GNULIB_VASPRINTF''@/1/g' \
-e 's/@''GNULIB_VDPRINTF''@/0/g' \
-e 's/@''GNULIB_VFPRINTF''@/1/g' \
-e 's/@''GNULIB_VFPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_VFSCANF''@/0/g' \
-e 's/@''GNULIB_VSCANF''@/0/g' \
-e 's/@''GNULIB_VPRINTF''@/1/g' \
-e 's/@''GNULIB_VPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_VSNPRINTF''@/1/g' \
-e 's/@''GNULIB_VSPRINTF_POSIX''@/0/g' \
< ./stdio.in.h | \
sed -e 's|@''HAVE_DECL_FPURGE''@|1|g' \
-e 's|@''HAVE_DECL_FSEEKO''@|1|g' \
-e 's|@''HAVE_DECL_FTELLO''@|1|g' \
-e 's|@''HAVE_DECL_GETDELIM''@|1|g' \
-e 's|@''HAVE_DECL_GETLINE''@|1|g' \
-e 's|@''HAVE_DECL_OBSTACK_PRINTF''@|1|g' \
-e 's|@''HAVE_DECL_SNPRINTF''@|1|g' \
-e 's|@''HAVE_DECL_VSNPRINTF''@|1|g' \
-e 's|@''HAVE_DPRINTF''@|1|g' \
-e 's|@''HAVE_FSEEKO''@|1|g' \
-e 's|@''HAVE_FTELLO''@|1|g' \
-e 's|@''HAVE_PCLOSE''@|1|g' \
-e 's|@''HAVE_POPEN''@|1|g' \
-e 's|@''HAVE_RENAMEAT''@|1|g' \
-e 's|@''HAVE_VASPRINTF''@|1|g' \
-e 's|@''HAVE_VDPRINTF''@|1|g' \
-e 's|@''REPLACE_DPRINTF''@|0|g' \
-e 's|@''REPLACE_FCLOSE''@|0|g' \
-e 's|@''REPLACE_FDOPEN''@|0|g' \
-e 's|@''REPLACE_FFLUSH''@|0|g' \
-e 's|@''REPLACE_FOPEN''@|0|g' \
-e 's|@''REPLACE_FPRINTF''@|0|g' \
-e 's|@''REPLACE_FPURGE''@|0|g' \
-e 's|@''REPLACE_FREOPEN''@|0|g' \
-e 's|@''REPLACE_FSEEK''@|0|g' \
-e 's|@''REPLACE_FSEEKO''@|0|g' \
-e 's|@''REPLACE_FTELL''@|0|g' \
-e 's|@''REPLACE_FTELLO''@|0|g' \
-e 's|@''REPLACE_GETDELIM''@|0|g' \
-e 's|@''REPLACE_GETLINE''@|0|g' \
-e 's|@''REPLACE_OBSTACK_PRINTF''@|0|g' \
-e 's|@''REPLACE_PERROR''@|0|g' \
-e 's|@''REPLACE_POPEN''@|0|g' \
-e 's|@''REPLACE_PRINTF''@|0|g' \
-e 's|@''REPLACE_REMOVE''@|0|g' \
-e 's|@''REPLACE_RENAME''@|0|g' \
-e 's|@''REPLACE_RENAMEAT''@|0|g' \
-e 's|@''REPLACE_SNPRINTF''@|0|g' \
-e 's|@''REPLACE_SPRINTF''@|0|g' \
-e 's|@''REPLACE_STDIO_READ_FUNCS''@|0|g' \
-e 's|@''REPLACE_STDIO_WRITE_FUNCS''@|0|g' \
-e 's|@''REPLACE_TMPFILE''@|0|g' \
-e 's|@''REPLACE_VASPRINTF''@|0|g' \
-e 's|@''REPLACE_VDPRINTF''@|0|g' \
-e 's|@''REPLACE_VFPRINTF''@|0|g' \
-e 's|@''REPLACE_VPRINTF''@|0|g' \
-e 's|@''REPLACE_VSNPRINTF''@|0|g' \
-e 's|@''REPLACE_VSPRINTF''@|0|g' \
-e 's|@''ASM_SYMBOL_PREFIX''@||g' \
} > stdio.h-t && \
mv stdio.h-t stdio.h
rm -f stdlib.h-t stdlib.h && \
-e 's|@''NEXT_STDLIB_H''@|<stdlib.h>|g' \
-e 's/@''GNULIB__EXIT''@/0/g' \
-e 's/@''GNULIB_ATOLL''@/0/g' \
-e 's/@''GNULIB_CALLOC_POSIX''@/0/g' \
-e 's/@''GNULIB_CANONICALIZE_FILE_NAME''@/0/g' \
-e 's/@''GNULIB_GETLOADAVG''@/1/g' \
-e 's/@''GNULIB_GETSUBOPT''@/0/g' \
-e 's/@''GNULIB_GRANTPT''@/0/g' \
-e 's/@''GNULIB_MALLOC_POSIX''@/1/g' \
-e 's/@''GNULIB_MBTOWC''@/1/g' \
-e 's/@''GNULIB_MKDTEMP''@/0/g' \
-e 's/@''GNULIB_MKOSTEMP''@/0/g' \
-e 's/@''GNULIB_MKOSTEMPS''@/0/g' \
-e 's/@''GNULIB_MKSTEMP''@/0/g' \
-e 's/@''GNULIB_MKSTEMPS''@/0/g' \
-e 's/@''GNULIB_POSIX_OPENPT''@/0/g' \
-e 's/@''GNULIB_PTSNAME''@/0/g' \
-e 's/@''GNULIB_PTSNAME_R''@/0/g' \
-e 's/@''GNULIB_PUTENV''@/0/g' \
-e 's/@''GNULIB_RANDOM''@/0/g' \
-e 's/@''GNULIB_RANDOM_R''@/0/g' \
-e 's/@''GNULIB_REALLOC_POSIX''@/0/g' \
-e 's/@''GNULIB_REALPATH''@/0/g' \
-e 's/@''GNULIB_RPMATCH''@/0/g' \
-e 's/@''GNULIB_SECURE_GETENV''@/0/g' \
-e 's/@''GNULIB_SETENV''@/1/g' \
-e 's/@''GNULIB_STRTOD''@/0/g' \
-e 's/@''GNULIB_STRTOLL''@/0/g' \
-e 's/@''GNULIB_STRTOULL''@/0/g' \
-e 's/@''GNULIB_SYSTEM_POSIX''@/0/g' \
-e 's/@''GNULIB_UNLOCKPT''@/0/g' \
-e 's/@''GNULIB_UNSETENV''@/1/g' \
-e 's/@''GNULIB_WCTOMB''@/0/g' \
< ./stdlib.in.h | \
sed -e 's|@''HAVE__EXIT''@|1|g' \
-e 's|@''HAVE_ATOLL''@|1|g' \
-e 's|@''HAVE_CANONICALIZE_FILE_NAME''@|1|g' \
-e 's|@''HAVE_DECL_GETLOADAVG''@|1|g' \
-e 's|@''HAVE_GETSUBOPT''@|1|g' \
-e 's|@''HAVE_GRANTPT''@|1|g' \
-e 's|@''HAVE_MKDTEMP''@|1|g' \
-e 's|@''HAVE_MKOSTEMP''@|1|g' \
-e 's|@''HAVE_MKOSTEMPS''@|1|g' \
-e 's|@''HAVE_MKSTEMP''@|1|g' \
-e 's|@''HAVE_MKSTEMPS''@|1|g' \
-e 's|@''HAVE_POSIX_OPENPT''@|1|g' \
-e 's|@''HAVE_PTSNAME''@|1|g' \
-e 's|@''HAVE_PTSNAME_R''@|1|g' \
-e 's|@''HAVE_RANDOM''@|1|g' \
-e 's|@''HAVE_RANDOM_H''@|1|g' \
-e 's|@''HAVE_RANDOM_R''@|1|g' \
-e 's|@''HAVE_REALPATH''@|1|g' \
-e 's|@''HAVE_RPMATCH''@|1|g' \
-e 's|@''HAVE_SECURE_GETENV''@|1|g' \
-e 's|@''HAVE_DECL_SETENV''@|1|g' \
-e 's|@''HAVE_STRTOD''@|1|g' \
-e 's|@''HAVE_STRTOLL''@|1|g' \
-e 's|@''HAVE_STRTOULL''@|1|g' \
-e 's|@''HAVE_STRUCT_RANDOM_DATA''@|1|g' \
-e 's|@''HAVE_SYS_LOADAVG_H''@|0|g' \
-e 's|@''HAVE_UNLOCKPT''@|1|g' \
-e 's|@''HAVE_DECL_UNSETENV''@|1|g' \
-e 's|@''REPLACE_CALLOC''@|0|g' \
-e 's|@''REPLACE_CANONICALIZE_FILE_NAME''@|0|g' \
-e 's|@''REPLACE_MALLOC''@|0|g' \
-e 's|@''REPLACE_MBTOWC''@|0|g' \
-e 's|@''REPLACE_MKSTEMP''@|0|g' \
-e 's|@''REPLACE_PTSNAME''@|0|g' \
-e 's|@''REPLACE_PTSNAME_R''@|0|g' \
-e 's|@''REPLACE_PUTENV''@|0|g' \
-e 's|@''REPLACE_RANDOM_R''@|0|g' \
-e 's|@''REPLACE_REALLOC''@|0|g' \
-e 's|@''REPLACE_REALPATH''@|0|g' \
-e 's|@''REPLACE_SETENV''@|1|g' \
-e 's|@''REPLACE_STRTOD''@|0|g' \
-e 's|@''REPLACE_UNSETENV''@|0|g' \
-e 's|@''REPLACE_WCTOMB''@|0|g' \
-e '/definition of _Noreturn/r ../build-aux/snippet/_Noreturn.h' \
} > stdlib.h-t && \
mv stdlib.h-t stdlib.h
rm -f string.h-t string.h && \
-e 's|@''NEXT_STRING_H''@|<string.h>|g' \
-e 's/@''GNULIB_FFSL''@/0/g' \
-e 's/@''GNULIB_FFSLL''@/0/g' \
-e 's/@''GNULIB_MBSLEN''@/0/g' \
-e 's/@''GNULIB_MBSNLEN''@/0/g' \
-e 's/@''GNULIB_MBSCHR''@/0/g' \
-e 's/@''GNULIB_MBSRCHR''@/0/g' \
-e 's/@''GNULIB_MBSSTR''@/0/g' \
-e 's/@''GNULIB_MBSCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSNCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSPCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSCASESTR''@/0/g' \
-e 's/@''GNULIB_MBSCSPN''@/0/g' \
-e 's/@''GNULIB_MBSPBRK''@/0/g' \
-e 's/@''GNULIB_MBSSPN''@/0/g' \
-e 's/@''GNULIB_MBSSEP''@/0/g' \
-e 's/@''GNULIB_MBSTOK_R''@/0/g' \
-e 's/@''GNULIB_MEMCHR''@/1/g' \
-e 's/@''GNULIB_MEMMEM''@/0/g' \
-e 's/@''GNULIB_MEMPCPY''@/0/g' \
-e 's/@''GNULIB_MEMRCHR''@/0/g' \
-e 's/@''GNULIB_RAWMEMCHR''@/0/g' \
-e 's/@''GNULIB_STPCPY''@/0/g' \
-e 's/@''GNULIB_STPNCPY''@/0/g' \
-e 's/@''GNULIB_STRCHRNUL''@/0/g' \
-e 's/@''GNULIB_STRDUP''@/0/g' \
-e 's/@''GNULIB_STRNCAT''@/0/g' \
-e 's/@''GNULIB_STRNDUP''@/1/g' \
-e 's/@''GNULIB_STRNLEN''@/1/g' \
-e 's/@''GNULIB_STRPBRK''@/0/g' \
-e 's/@''GNULIB_STRSEP''@/1/g' \
-e 's/@''GNULIB_STRSTR''@/1/g' \
-e 's/@''GNULIB_STRCASESTR''@/0/g' \
-e 's/@''GNULIB_STRTOK_R''@/0/g' \
-e 's/@''GNULIB_STRERROR''@/1/g' \
-e 's/@''GNULIB_STRERROR_R''@/0/g' \
-e 's/@''GNULIB_STRSIGNAL''@/0/g' \
-e 's/@''GNULIB_STRVERSCMP''@/0/g' \
< ./string.in.h | \
sed -e 's|@''HAVE_FFSL''@|1|g' \
-e 's|@''HAVE_FFSLL''@|1|g' \
-e 's|@''HAVE_MBSLEN''@|0|g' \
-e 's|@''HAVE_MEMCHR''@|1|g' \
-e 's|@''HAVE_DECL_MEMMEM''@|1|g' \
-e 's|@''HAVE_MEMPCPY''@|1|g' \
-e 's|@''HAVE_DECL_MEMRCHR''@|1|g' \
-e 's|@''HAVE_RAWMEMCHR''@|1|g' \
-e 's|@''HAVE_STPCPY''@|1|g' \
-e 's|@''HAVE_STPNCPY''@|1|g' \
-e 's|@''HAVE_STRCHRNUL''@|1|g' \
-e 's|@''HAVE_DECL_STRDUP''@|1|g' \
-e 's|@''HAVE_DECL_STRNDUP''@|1|g' \
-e 's|@''HAVE_DECL_STRNLEN''@|1|g' \
-e 's|@''HAVE_STRPBRK''@|1|g' \
-e 's|@''HAVE_STRSEP''@|1|g' \
-e 's|@''HAVE_STRCASESTR''@|1|g' \
-e 's|@''HAVE_DECL_STRTOK_R''@|1|g' \
-e 's|@''HAVE_DECL_STRERROR_R''@|1|g' \
-e 's|@''HAVE_DECL_STRSIGNAL''@|1|g' \
-e 's|@''HAVE_STRVERSCMP''@|1|g' \
-e 's|@''REPLACE_STPNCPY''@|0|g' \
-e 's|@''REPLACE_MEMCHR''@|0|g' \
-e 's|@''REPLACE_MEMMEM''@|0|g' \
-e 's|@''REPLACE_STRCASESTR''@|0|g' \
-e 's|@''REPLACE_STRCHRNUL''@|0|g' \
-e 's|@''REPLACE_STRDUP''@|0|g' \
-e 's|@''REPLACE_STRSTR''@|0|g' \
-e 's|@''REPLACE_STRERROR''@|1|g' \
-e 's|@''REPLACE_STRERROR_R''@|0|g' \
-e 's|@''REPLACE_STRNCAT''@|0|g' \
-e 's|@''REPLACE_STRNDUP''@|0|g' \
-e 's|@''REPLACE_STRNLEN''@|0|g' \
-e 's|@''REPLACE_STRSIGNAL''@|0|g' \
-e 's|@''REPLACE_STRTOK_R''@|0|g' \
-e 's|@''UNDEFINE_STRTOK_R''@|0|g' \
< ./string.in.h; \
} > string.h-t && \
mv string.h-t string.h
/bin/mkdir -p sys
rm -f sys/socket.h-t sys/socket.h && \
-e 's|@''NEXT_SYS_SOCKET_H''@|<sys/socket.h>|g' \
-e 's|@''HAVE_SYS_SOCKET_H''@|1|g' \
-e 's/@''GNULIB_CLOSE''@/0/g' \
-e 's/@''GNULIB_SOCKET''@/0/g' \
-e 's/@''GNULIB_CONNECT''@/0/g' \
-e 's/@''GNULIB_ACCEPT''@/0/g' \
-e 's/@''GNULIB_BIND''@/0/g' \
-e 's/@''GNULIB_GETPEERNAME''@/0/g' \
-e 's/@''GNULIB_GETSOCKNAME''@/0/g' \
-e 's/@''GNULIB_GETSOCKOPT''@/0/g' \
-e 's/@''GNULIB_LISTEN''@/0/g' \
-e 's/@''GNULIB_RECV''@/0/g' \
-e 's/@''GNULIB_SEND''@/0/g' \
-e 's/@''GNULIB_RECVFROM''@/0/g' \
-e 's/@''GNULIB_SENDTO''@/0/g' \
-e 's/@''GNULIB_SETSOCKOPT''@/0/g' \
-e 's/@''GNULIB_SHUTDOWN''@/0/g' \
-e 's/@''GNULIB_ACCEPT4''@/0/g' \
-e 's|@''HAVE_WINSOCK2_H''@|0|g' \
-e 's|@''HAVE_WS2TCPIP_H''@|0|g' \
-e 's|@''HAVE_STRUCT_SOCKADDR_STORAGE''@|1|g' \
-e 's|@''HAVE_STRUCT_SOCKADDR_STORAGE_SS_FAMILY''@|1|g' \
-e 's|@''HAVE_SA_FAMILY_T''@|1|g' \
-e 's|@''HAVE_ACCEPT4''@|1|g' \
< ./sys_socket.in.h; \
} > sys/socket.h-t && \
mv -f sys/socket.h-t sys/socket.h
/bin/mkdir -p sys
rm -f sys/types.h-t sys/types.h && \
-e 's|@''NEXT_SYS_TYPES_H''@|<sys/types.h>|g' \
-e 's|@''WINDOWS_64_BIT_OFF_T''@|0|g' \
< ./sys_types.in.h; \
} > sys/types.h-t && \
mv sys/types.h-t sys/types.h
/bin/mkdir -p sys
rm -f sys/uio.h-t sys/uio.h && \
-e 's|@''NEXT_SYS_UIO_H''@|<sys/uio.h>|g' \
-e 's|@''HAVE_SYS_UIO_H''@|1|g' \
< ./sys_uio.in.h; \
} > sys/uio.h-t && \
mv -f sys/uio.h-t sys/uio.h
rm -f time.h-t time.h && \
-e 's|@''NEXT_TIME_H''@|<time.h>|g' \
-e 's/@''GNULIB_MKTIME''@/1/g' \
-e 's/@''GNULIB_NANOSLEEP''@/0/g' \
-e 's/@''GNULIB_STRPTIME''@/0/g' \
-e 's/@''GNULIB_TIMEGM''@/1/g' \
-e 's/@''GNULIB_TIME_R''@/1/g' \
-e 's|@''HAVE_DECL_LOCALTIME_R''@|1|g' \
-e 's|@''HAVE_NANOSLEEP''@|1|g' \
-e 's|@''HAVE_STRPTIME''@|1|g' \
-e 's|@''HAVE_TIMEGM''@|1|g' \
-e 's|@''REPLACE_LOCALTIME_R''@|0|g' \
-e 's|@''REPLACE_MKTIME''@|1|g' \
-e 's|@''REPLACE_NANOSLEEP''@|GNULIB_PORTCHECK|g' \
-e 's|@''REPLACE_TIMEGM''@|0|g' \
-e 's|@''PTHREAD_H_DEFINES_STRUCT_TIMESPEC''@|0|g' \
-e 's|@''SYS_TIME_H_DEFINES_STRUCT_TIMESPEC''@|0|g' \
-e 's|@''TIME_H_DEFINES_STRUCT_TIMESPEC''@|1|g' \
< ./time.in.h; \
} > time.h-t && \
mv time.h-t time.h
rm -f unistd.h-t unistd.h && \
-e 's|@''HAVE_UNISTD_H''@|1|g' \
-e 's|@''NEXT_UNISTD_H''@|<unistd.h>|g' \
-e 's/@''GNULIB_CHDIR''@/0/g' \
-e 's/@''GNULIB_CHOWN''@/0/g' \
-e 's/@''GNULIB_DUP''@/0/g' \
-e 's/@''GNULIB_DUP2''@/0/g' \
-e 's/@''GNULIB_DUP3''@/0/g' \
-e 's/@''GNULIB_ENVIRON''@/1/g' \
-e 's/@''GNULIB_EUIDACCESS''@/0/g' \
-e 's/@''GNULIB_FACCESSAT''@/0/g' \
-e 's/@''GNULIB_FCHDIR''@/0/g' \
-e 's/@''GNULIB_FCHOWNAT''@/0/g' \
-e 's/@''GNULIB_FDATASYNC''@/0/g' \
-e 's/@''GNULIB_FSYNC''@/0/g' \
-e 's/@''GNULIB_FTRUNCATE''@/0/g' \
-e 's/@''GNULIB_GETCWD''@/0/g' \
-e 's/@''GNULIB_GETDOMAINNAME''@/0/g' \
-e 's/@''GNULIB_GETDTABLESIZE''@/0/g' \
-e 's/@''GNULIB_GETGROUPS''@/0/g' \
-e 's/@''GNULIB_GETHOSTNAME''@/1/g' \
-e 's/@''GNULIB_GETLOGIN''@/0/g' \
-e 's/@''GNULIB_GETLOGIN_R''@/0/g' \
-e 's/@''GNULIB_GETPAGESIZE''@/0/g' \
-e 's/@''GNULIB_GETUSERSHELL''@/0/g' \
-e 's/@''GNULIB_GROUP_MEMBER''@/0/g' \
-e 's/@''GNULIB_ISATTY''@/0/g' \
-e 's/@''GNULIB_LCHOWN''@/0/g' \
-e 's/@''GNULIB_LINK''@/0/g' \
-e 's/@''GNULIB_LINKAT''@/0/g' \
-e 's/@''GNULIB_LSEEK''@/0/g' \
-e 's/@''GNULIB_PIPE''@/0/g' \
-e 's/@''GNULIB_PIPE2''@/0/g' \
-e 's/@''GNULIB_PREAD''@/0/g' \
-e 's/@''GNULIB_PWRITE''@/0/g' \
-e 's/@''GNULIB_READ''@/1/g' \
-e 's/@''GNULIB_READLINK''@/0/g' \
-e 's/@''GNULIB_READLINKAT''@/0/g' \
-e 's/@''GNULIB_RMDIR''@/0/g' \
-e 's/@''GNULIB_SETHOSTNAME''@/0/g' \
-e 's/@''GNULIB_SLEEP''@/0/g' \
-e 's/@''GNULIB_SYMLINK''@/0/g' \
-e 's/@''GNULIB_SYMLINKAT''@/0/g' \
-e 's/@''GNULIB_TTYNAME_R''@/0/g' \
-e 's/@''GNULIB_UNISTD_H_GETOPT''@/01/g' \
-e 's/@''GNULIB_UNISTD_H_NONBLOCKING''@/0/g' \
-e 's/@''GNULIB_UNISTD_H_SIGPIPE''@/0/g' \
-e 's/@''GNULIB_UNLINK''@/0/g' \
-e 's/@''GNULIB_UNLINKAT''@/0/g' \
-e 's/@''GNULIB_USLEEP''@/0/g' \
-e 's/@''GNULIB_WRITE''@/0/g' \
< ./unistd.in.h | \
sed -e 's|@''HAVE_CHOWN''@|1|g' \
-e 's|@''HAVE_DUP2''@|1|g' \
-e 's|@''HAVE_DUP3''@|1|g' \
-e 's|@''HAVE_EUIDACCESS''@|1|g' \
-e 's|@''HAVE_FACCESSAT''@|1|g' \
-e 's|@''HAVE_FCHDIR''@|1|g' \
-e 's|@''HAVE_FCHOWNAT''@|1|g' \
-e 's|@''HAVE_FDATASYNC''@|1|g' \
-e 's|@''HAVE_FSYNC''@|1|g' \
-e 's|@''HAVE_FTRUNCATE''@|1|g' \
-e 's|@''HAVE_GETDTABLESIZE''@|1|g' \
-e 's|@''HAVE_GETGROUPS''@|1|g' \
-e 's|@''HAVE_GETHOSTNAME''@|1|g' \
-e 's|@''HAVE_GETLOGIN''@|1|g' \
-e 's|@''HAVE_GETPAGESIZE''@|1|g' \
-e 's|@''HAVE_GROUP_MEMBER''@|1|g' \
-e 's|@''HAVE_LCHOWN''@|1|g' \
-e 's|@''HAVE_LINK''@|1|g' \
-e 's|@''HAVE_LINKAT''@|1|g' \
-e 's|@''HAVE_PIPE''@|1|g' \
-e 's|@''HAVE_PIPE2''@|1|g' \
-e 's|@''HAVE_PREAD''@|1|g' \
-e 's|@''HAVE_PWRITE''@|1|g' \
-e 's|@''HAVE_READLINK''@|1|g' \
-e 's|@''HAVE_READLINKAT''@|1|g' \
-e 's|@''HAVE_SETHOSTNAME''@|1|g' \
-e 's|@''HAVE_SLEEP''@|1|g' \
-e 's|@''HAVE_SYMLINK''@|1|g' \
-e 's|@''HAVE_SYMLINKAT''@|1|g' \
-e 's|@''HAVE_UNLINKAT''@|1|g' \
-e 's|@''HAVE_USLEEP''@|1|g' \
-e 's|@''HAVE_DECL_ENVIRON''@|1|g' \
-e 's|@''HAVE_DECL_FCHDIR''@|1|g' \
-e 's|@''HAVE_DECL_FDATASYNC''@|1|g' \
-e 's|@''HAVE_DECL_GETDOMAINNAME''@|1|g' \
-e 's|@''HAVE_DECL_GETLOGIN_R''@|1|g' \
-e 's|@''HAVE_DECL_GETPAGESIZE''@|1|g' \
-e 's|@''HAVE_DECL_GETUSERSHELL''@|1|g' \
-e 's|@''HAVE_DECL_SETHOSTNAME''@|1|g' \
-e 's|@''HAVE_DECL_TTYNAME_R''@|1|g' \
-e 's|@''HAVE_OS_H''@|0|g' \
-e 's|@''HAVE_SYS_PARAM_H''@|0|g' \
sed -e 's|@''REPLACE_CHOWN''@|0|g' \
-e 's|@''REPLACE_CLOSE''@|0|g' \
-e 's|@''REPLACE_DUP''@|0|g' \
-e 's|@''REPLACE_DUP2''@|0|g' \
-e 's|@''REPLACE_FCHOWNAT''@|0|g' \
-e 's|@''REPLACE_FTRUNCATE''@|0|g' \
-e 's|@''REPLACE_GETCWD''@|0|g' \
-e 's|@''REPLACE_GETDOMAINNAME''@|0|g' \
-e 's|@''REPLACE_GETLOGIN_R''@|0|g' \
-e 's|@''REPLACE_GETGROUPS''@|0|g' \
-e 's|@''REPLACE_GETPAGESIZE''@|0|g' \
-e 's|@''REPLACE_ISATTY''@|0|g' \
-e 's|@''REPLACE_LCHOWN''@|0|g' \
-e 's|@''REPLACE_LINK''@|0|g' \
-e 's|@''REPLACE_LINKAT''@|0|g' \
-e 's|@''REPLACE_LSEEK''@|0|g' \
-e 's|@''REPLACE_PREAD''@|0|g' \
-e 's|@''REPLACE_PWRITE''@|0|g' \
-e 's|@''REPLACE_READ''@|0|g' \
-e 's|@''REPLACE_READLINK''@|0|g' \
-e 's|@''REPLACE_RMDIR''@|0|g' \
-e 's|@''REPLACE_SLEEP''@|0|g' \
-e 's|@''REPLACE_SYMLINK''@|0|g' \
-e 's|@''REPLACE_TTYNAME_R''@|0|g' \
-e 's|@''REPLACE_UNLINK''@|0|g' \
-e 's|@''REPLACE_UNLINKAT''@|0|g' \
-e 's|@''REPLACE_USLEEP''@|0|g' \
-e 's|@''REPLACE_WRITE''@|0|g' \
-e 's|@''UNISTD_H_HAVE_WINSOCK2_H''@|0|g' \
-e 's|@''UNISTD_H_HAVE_WINSOCK2_H_AND_USE_SOCKETS''@|0|g' \
} > unistd.h-t && \
mv unistd.h-t unistd.h
rm -f wchar.h-t wchar.h && \
-e 's|@''NEXT_WCHAR_H''@|<wchar.h>|g' \
-e 's|@''HAVE_WCHAR_H''@|1|g' \
-e 's/@''GNULIB_BTOWC''@/1/g' \
-e 's/@''GNULIB_WCTOB''@/0/g' \
-e 's/@''GNULIB_MBSINIT''@/1/g' \
-e 's/@''GNULIB_MBRTOWC''@/1/g' \
-e 's/@''GNULIB_MBRLEN''@/0/g' \
-e 's/@''GNULIB_MBSRTOWCS''@/0/g' \
-e 's/@''GNULIB_MBSNRTOWCS''@/0/g' \
-e 's/@''GNULIB_WCRTOMB''@/1/g' \
-e 's/@''GNULIB_WCSRTOMBS''@/0/g' \
-e 's/@''GNULIB_WCSNRTOMBS''@/0/g' \
-e 's/@''GNULIB_WCWIDTH''@/0/g' \
-e 's/@''GNULIB_WMEMCHR''@/0/g' \
-e 's/@''GNULIB_WMEMCMP''@/0/g' \
-e 's/@''GNULIB_WMEMCPY''@/0/g' \
-e 's/@''GNULIB_WMEMMOVE''@/0/g' \
-e 's/@''GNULIB_WMEMSET''@/0/g' \
-e 's/@''GNULIB_WCSLEN''@/0/g' \
-e 's/@''GNULIB_WCSNLEN''@/0/g' \
-e 's/@''GNULIB_WCSCPY''@/0/g' \
-e 's/@''GNULIB_WCPCPY''@/0/g' \
-e 's/@''GNULIB_WCSNCPY''@/0/g' \
-e 's/@''GNULIB_WCPNCPY''@/0/g' \
-e 's/@''GNULIB_WCSCAT''@/0/g' \
-e 's/@''GNULIB_WCSNCAT''@/0/g' \
-e 's/@''GNULIB_WCSCMP''@/0/g' \
-e 's/@''GNULIB_WCSNCMP''@/0/g' \
-e 's/@''GNULIB_WCSCASECMP''@/0/g' \
-e 's/@''GNULIB_WCSNCASECMP''@/0/g' \
-e 's/@''GNULIB_WCSCOLL''@/0/g' \
-e 's/@''GNULIB_WCSXFRM''@/0/g' \
-e 's/@''GNULIB_WCSDUP''@/0/g' \
-e 's/@''GNULIB_WCSCHR''@/0/g' \
-e 's/@''GNULIB_WCSRCHR''@/0/g' \
-e 's/@''GNULIB_WCSCSPN''@/0/g' \
-e 's/@''GNULIB_WCSSPN''@/0/g' \
-e 's/@''GNULIB_WCSPBRK''@/0/g' \
-e 's/@''GNULIB_WCSSTR''@/0/g' \
-e 's/@''GNULIB_WCSTOK''@/0/g' \
-e 's/@''GNULIB_WCSWIDTH''@/0/g' \
< ./wchar.in.h | \
sed -e 's|@''HAVE_WINT_T''@|1|g' \
-e 's|@''HAVE_BTOWC''@|1|g' \
-e 's|@''HAVE_MBSINIT''@|1|g' \
-e 's|@''HAVE_MBRTOWC''@|1|g' \
-e 's|@''HAVE_MBRLEN''@|1|g' \
-e 's|@''HAVE_MBSRTOWCS''@|1|g' \
-e 's|@''HAVE_MBSNRTOWCS''@|1|g' \
-e 's|@''HAVE_WCRTOMB''@|1|g' \
-e 's|@''HAVE_WCSRTOMBS''@|1|g' \
-e 's|@''HAVE_WCSNRTOMBS''@|1|g' \
-e 's|@''HAVE_WMEMCHR''@|1|g' \
-e 's|@''HAVE_WMEMCMP''@|1|g' \
-e 's|@''HAVE_WMEMCPY''@|1|g' \
-e 's|@''HAVE_WMEMMOVE''@|1|g' \
-e 's|@''HAVE_WMEMSET''@|1|g' \
-e 's|@''HAVE_WCSLEN''@|1|g' \
-e 's|@''HAVE_WCSNLEN''@|1|g' \
-e 's|@''HAVE_WCSCPY''@|1|g' \
-e 's|@''HAVE_WCPCPY''@|1|g' \
-e 's|@''HAVE_WCSNCPY''@|1|g' \
-e 's|@''HAVE_WCPNCPY''@|1|g' \
-e 's|@''HAVE_WCSCAT''@|1|g' \
-e 's|@''HAVE_WCSNCAT''@|1|g' \
-e 's|@''HAVE_WCSCMP''@|1|g' \
-e 's|@''HAVE_WCSNCMP''@|1|g' \
-e 's|@''HAVE_WCSCASECMP''@|1|g' \
-e 's|@''HAVE_WCSNCASECMP''@|1|g' \
-e 's|@''HAVE_WCSCOLL''@|1|g' \
-e 's|@''HAVE_WCSXFRM''@|1|g' \
-e 's|@''HAVE_WCSDUP''@|1|g' \
-e 's|@''HAVE_WCSCHR''@|1|g' \
-e 's|@''HAVE_WCSRCHR''@|1|g' \
-e 's|@''HAVE_WCSCSPN''@|1|g' \
-e 's|@''HAVE_WCSSPN''@|1|g' \
-e 's|@''HAVE_WCSPBRK''@|1|g' \
-e 's|@''HAVE_WCSSTR''@|1|g' \
-e 's|@''HAVE_WCSTOK''@|1|g' \
-e 's|@''HAVE_WCSWIDTH''@|1|g' \
-e 's|@''HAVE_DECL_WCTOB''@|1|g' \
-e 's|@''HAVE_DECL_WCWIDTH''@|1|g' \
sed -e 's|@''REPLACE_MBSTATE_T''@|0|g' \
-e 's|@''REPLACE_BTOWC''@|0|g' \
-e 's|@''REPLACE_WCTOB''@|0|g' \
-e 's|@''REPLACE_MBSINIT''@|0|g' \
-e 's|@''REPLACE_MBRTOWC''@|0|g' \
-e 's|@''REPLACE_MBRLEN''@|0|g' \
-e 's|@''REPLACE_MBSRTOWCS''@|0|g' \
-e 's|@''REPLACE_MBSNRTOWCS''@|0|g' \
-e 's|@''REPLACE_WCRTOMB''@|0|g' \
-e 's|@''REPLACE_WCSRTOMBS''@|0|g' \
-e 's|@''REPLACE_WCSNRTOMBS''@|0|g' \
-e 's|@''REPLACE_WCWIDTH''@|0|g' \
-e 's|@''REPLACE_WCSWIDTH''@|0|g' \
} > wchar.h-t && \
mv wchar.h-t wchar.h
rm -f wctype.h-t wctype.h && \
-e 's/@''HAVE_WCTYPE_H''@/1/g' \
-e 's|@''NEXT_WCTYPE_H''@|<wctype.h>|g' \
-e 's/@''GNULIB_ISWBLANK''@/0/g' \
-e 's/@''GNULIB_WCTYPE''@/0/g' \
-e 's/@''GNULIB_ISWCTYPE''@/0/g' \
-e 's/@''GNULIB_WCTRANS''@/0/g' \
-e 's/@''GNULIB_TOWCTRANS''@/0/g' \
-e 's/@''HAVE_ISWBLANK''@/1/g' \
-e 's/@''HAVE_ISWCNTRL''@/1/g' \
-e 's/@''HAVE_WCTYPE_T''@/1/g' \
-e 's/@''HAVE_WCTRANS_T''@/1/g' \
-e 's/@''HAVE_WINT_T''@/1/g' \
-e 's/@''REPLACE_ISWBLANK''@/0/g' \
-e 's/@''REPLACE_ISWCNTRL''@/0/g' \
-e 's/@''REPLACE_TOWLOWER''@/0/g' \
< ./wctype.in.h; \
} > wctype.h-t && \
mv wctype.h-t wctype.h
make all-recursive
make[3]: Entering directory `/tmp/nagios-plugins-2.1.1/gl'
make[4]: Entering directory `/tmp/nagios-plugins-2.1.1/gl'
depbase=`echo base64.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT base64.o -MD
mv -f $depbase.Tpo $depbase.Po
depbase=`echo sha1.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT sha1.o -MD -M
depbase=`echo dirname.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT dirname.o -MD
depbase=`echo basename.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT basename.o -M
depbase=`echo dirname-lgpl.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT dirname-lgpl.
depbase=`echo basename-lgpl.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT basename-lgpl
depbase=`echo stripslash.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT stripslash.o
depbase=`echo exitfail.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT exitfail.o -M
depbase=`echo fd-hook.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT fd-hook.o -MD
depbase=`echo full-read.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT full-read.o -
depbase=`echo idpriv-droptemp.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT idpriv-dropte
depbase=`echo localcharset.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT localcharset.
depbase=`echo glthread/lock.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT glthread/lock
depbase=`echo malloca.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT malloca.o -MD
depbase=`echo math.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT math.o -MD -M
depbase=`echo safe-read.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT safe-read.o -
depbase=`echo sys_socket.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT sys_socket.o
depbase=`echo glthread/threadlib.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT glthread/thre
depbase=`echo unistd.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT unistd.o -MD
depbase=`echo wctype-h.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT wctype-h.o -M
depbase=`echo xmalloc.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT xmalloc.o -MD
depbase=`echo xalloc-die.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT xalloc-die.o
depbase=`echo xsize.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT xsize.o -MD -
depbase=`echo xstrndup.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT xstrndup.o -M
depbase=`echo fsusage.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/kerberos/include -g -O2 -MT fsusage.o -MD
I've seen similar issues when openssl-devel is not installed. Can you run the following command and show the output?
yum list installed openssl*Be sure to check out our Knowledgebase for helpful articles and solutions!
Please find the output.
[root@triserv nagios]$ rpm -qa |grep -i openssl*
openssh-askpass-gnome-3.1p1-2
openssl-0.9.6b-17
openssh-askpass-3.1p1-2
openssh-clients-3.1p1-2
openssh-server-3.1p1-2
openssl-devel-0.9.6b-17
openssh-3.1p1-2
openssl-0.9.6b-17
openssh-3.1p1-2
Have you installed all of the other pre-reqs?
yum install gcc glibc glibc-common xinetd
yum command do not work on this server. I tried with rpm and get below error
rpm -ivh gcc glibc glibc-common xinetd
error: open of gcc failed: No such file or directory
error: open of glibc failed: No such file or directory
error: open of glibc-common failed: No such file or directory
error: open of xinetd failed: No such file or directory
You will need to download those individual RPM's for each package.
Is using check by ssh an option for what you'd like to monitor?
check_by_ssh option also need plugins installed on monitoring machine, then how can it be installed without these dependencies?
As rkennedy suggested, if yum is not available on this system, you will need to download all of the needed RPMs manually and install them. It's a lot easier to use yum as it takes care of dependencies. With RPMs, you will need to deal with dependencies yourself.
RHEL 2.x is very old... Is there any chance you upgrade?
You will need to have nagios plugins installed whether you use "check_nrpe" or "check-by-ssh".check_by_ssh option also need plugins installed on monitoring machine, then how can it be installed without these dependencies?
