Custom Actions Question
BanditBBS
Post by BanditBBS »
Ok, so I can guess the custom actions component is running commands as apache, right?
If I am correct on that, what on earth do I need to add to the sudoers file to allow apache to run this command: sudo -i -u nagios /usr/local/nagios/libexec/cdm-update.sh %hostaddress%
Any ideas?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Custom Actions Question
Is there any reason why you want to use "sudo -i -u nagios"? I tried the following scenario, which worked OK for me.
In the Actions component:
/usr/local/nagios/libexec/ping.sh %hostaddress%
ping.sh
#!/bin/bash
/usr/local/nagios/libexec/check_ping -H $1 -w 100.0,20% -c 500.0,60% -p 3 -4
exit 0
ll ping.sh
-rwxr-xr-- 1 nagios nagios 97 Nov  6 12:37 ping.sh
I didn't need to modify the sudoers.
BanditBBS
Post by BanditBBS »
I need it executed as nagios from nagios' shell. The script does some scp and for key issues it needs to be as nagios.
Something like this?
NEWSCRIPT.sh
#!/bin/bash
sudo -i -u nagios /usr/local/nagios/libexec/cdm-update.sh $1
visudo
apache ALL = NOPASSWD:/usr/local/nagios/libexec/NEWSCRIPT.sh *
Add action for
/usr/local/nagios/libexec/NEWSCRIPT.sh %hostaddress%
@BanditBBS
I tried something similar and it worked but this could be a security issue... I can PM you my configs if you want me to.
BanditBBS
Post by BanditBBS »
lmiltchev wrote:@BanditBBS
Please. if it doesn't work for me I'll then post in much more detail what I'm trying to do.
I sent you a PM.
BanditBBS
Post by BanditBBS »
Go ahead and close this up!
Your PM didn't work for me, but it was along the same lines I was going and eventually it would have ended up being security issue. So, instead I created a couple scripts to output the hostaddress to a file and put those as actions. Then I just put a cron job in for nagios that runs every 5 minutes that uses those files.
Thanks for trying though!
Yeah, as I said, this could be a security issue. I worked for me, but I didn't like the "workaround", either. :)
I am glad you found a better way!
I am locking this topic.
