How to delete hosts from the dependent database
When I try to delete hosts. It says it is depended relationship. What is the procedure to delete the host completely.
Re: How to delete hosts from the dependent database
First, you must delete/change all of the dependencies of your particular host. The easiest way to find the dependencies is by clicking the small blue 'i' icon in 'Config -> Core Config Manager -> Hosts':
After clicking the small 'i' icon, all dependencies will be revealed. It is very likely that your dependencies will be mostly services - Navigate to the 'services' tab and remove the appropriate services. After doing so, you should be able to delete the host in question.
