syslog-ng instead of syslogd
comfone
Post by comfone »
We have started to use syslog-ng instead of syslogd.
How can I configure or OpenSuse13.1 Server to send the syslog to our NagiosLogServer.
Thank you for your help.
jolson
Attack Rabbit
Re: syslog-ng instead of syslogd
Post by jolson »
Using syslog-ng, your configuration should look something like this:
Add the following to /etc/syslog.conf:
source s_src { unix-dgram("/dev/log"); internal(); file("/proc/kmsg"
   program_override("kernel"));
destination d_logstash { tcp("10.0.0.1" port(5544)); };
log { source(s_src); destination(d_logstash); };
Be sure to replace '10.0.0.1' with the IP address of a Nagios Log Server node. You're also free to change the port as you desire. After adding the above to your configuration file, be sure to restart syslog-ng.
sudo /etc/init.d/syslog-ng restart
Twits Blog
This file is also often located at /etc/syslog-ng/syslog-ng.conf
I am also adding documentation for syslog-ng to the next version of Log Server
Improving on this post, I would recommend settings like this, to be sure we are setting the syslog-protocol flag
source s_nagios {
	system();
	internal();
destination d_nagios {
    tcp("%hostname%" port(5544) flags(syslog-protocol));
log {
	source(s_nagios);
	destination(s_nagios);
This time replacing %hostname% with the hostname of your Log Server cluster
comfone
Post by comfone »
Thank you for your reply.
Could you please help me to forward apache2 logs to Nagios Log Server also using syslog-ng?
I would like to send all log files under /var/log/apache2/ to our Nagios Log Server and configure a filter to recognize them.
Thank you.
Something like this:
source s_nagios {
	system();
	internal();
source s_apache2 {
   file("/var/log/apache2/*" flags(no-parse));
log {
	source(s_nagios);
	source(s_apache2);
	destination(d_nagios);
comfone
Post by comfone »
Hi Scott
Is there a default filter on the Nagios Log Server which I can apply for apache2 logs?
All your documentation is based on "rsyslog.conf" :(
jolson
Attack Rabbit
Post by jolson »
The included filter can be viewed at 'Administration -> Global Configuration'. The filter should apply if your apache logs are detected appropriately. If not, you might find some of my older write-ups useful regarding filter construction:
http://support.nagios.com/forum/viewtop ... 37&t=32221
http://support.nagios.com/forum/viewtop ... 68#p134768
http://support.nagios.com/forum/viewtop ... 28#p137728
Twits Blog
comfone
Post by comfone »
How can I make sure that they are detected?
Can I "flag" them in the syslong-ng.conf?
The closest I could find was this:
https://www.balabit.com/sites/default/f ... sages.html
That will just let you know if syslog-ng is working, not whether it has sent a particular message to NLS. That might be a question for the syslog-ng forums.
comfone
Post by comfone »
I have solved my problem as follow:
1. Create "Inputs" for Apache Access Logs
udp {
type => "apache_access_log"
port => 3333
2. Create "Inputs" for the Apache Error Logs
udp {
type => "apache_error_log"
port => 3334
3. Create following"Filter":
if [type] == 'apache_access_log' {
grok {
match => [ 'message', '%{COMMONAPACHELOG}']
geoip {
source => 'clientip'
date {
match => [ 'timestamp', 'dd/MMM/yyyy:HH:mm:ss Z' ]
mutate {
replace => [ 'type', 'apache_access' ]
convert => [ 'bytes', 'integer' ]
convert => [ 'response', 'integer' ]
if [type] == 'apache_error_log' {
grok {
match => [ 'message', '\[(?<timestamp>%{DAY:day} %{MONTH:month} %{MONTHDAY} %{TIME} %{YEAR})\] \[.*:%{LOGLEVEL:loglevel}\] \[pid %{NUMBER:pid}\] \[client %{IP:clientip}:.*\] %{GREEDYDATA:errormsg}']
mutate {
replace => [ 'type', 'apache_error' ]
Thank you all for your help.
Cheers,
