Hi All,
i tried to find nscp agent for redhat 5, but i didn't found.
Anybody can help me with my search?
NSCP agent for Redhat 5
murawweh.daher
Regards,
Murawweh Daher
Murawweh Daher
Re: NSCP agent for Redhat 5
NSCP is for Windows. What you're going to be wanting to look for is NRPE. Take a look at this: https://assets.nagios.com/downloads/nag ... _Agent.pdf
Former Nagios Employee.
me.
me.
In fact Nsclient is also available on Linux, but I have absolutely no experience with it.
http://www.nsclient.org/download/
I would also suggest the Nagios nrpe agent which is very stable. Never had any problem with it.
EDIT: Sorry apparently not for Red Hat 5 I see now..
Nagios XI 5.8.1
https://outsideit.net
Thanks Willem, I wasn't actually aware of that. I've probably seen it 50 times too. Sometimes it takes 51 times to register
me.
me.
murawweh.daher
Hi All,
i tried to install nrpe but i have below message, and what is the prerequest of no inernet connection available on host?
Error: Cannot retrieve repository metadata (repomd.xml) for repository: epel. Please verify its path and try again
Could not retrieve mirrorlist http://mirrors.fedoraproject.org/mirror ... rch=x86_64 error was
[Errno 4] IOError: <urlopen error (97, 'Address family not supported by protocol')>
Regards,
Murawweh Daher
Murawweh Daher
What is your internet situation on the host?
me.
me.
murawweh.daher
we can't active the internet on this host (security issue).
Regards,
Murawweh Daher
Murawweh Daher
Unfortunately we don't have an "offline" NRPE installer. You can try downloading the Linux agent (NRPE + Nagios plugins) on the different machine (with Internet access) and moving it over to your Redhat 5 server.
https://assets.nagios.com/downloads/nag ... ent.tar.gz
Untar the file, cd into the linux-nrpe-agent directory and run:
Find a way to install the prerequisites manually on the Redhat 5 machine - autoconf, gcc, glibc, libmcrypt-devel, make, openssl-devel, sudo, sysstat, xinetd, and bc.
Run the fullinstall script:
This may or may not work. Again, we don't have a "offline" installer. This is a "workaround".
touch installed.repos
touch installed.prereqsRun the fullinstall script:
cd /tmp/linux-nrpe-agent
./fullinstallBe sure to check out our Knowledgebase for helpful articles and solutions!
