<snip>
chmod +x check_mysql_health
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/plugins-scripts'
Making all in t
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/t'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2/t'
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2'
make[1]: Nothing to be done for `all-am'.
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/extraplugins/check_mysql_health-2.1.8.2'
Warning: prerequisite Class::Accessor 0 not found.
Warning: prerequisite Config::Tiny 0 not found.
Warning: prerequisite Math::Calc::Units 0 not found.
Warning: prerequisite Test::More 0.62 not found.
Writing Makefile for Nagios::Monitoring::Plugin
Skip blib/lib/Nagios/Monitoring/Plugin/Performance.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/Range.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/Threshold.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/Config.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/Functions.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/Getopt.pm (unchanged)
Skip blib/lib/Nagios/Monitoring/Plugin/ExitResult.pm (unchanged)
Manifying blib/man3/Nagios::Monitoring::Plugin::Performance.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::Range.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::Threshold.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::Getopt.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::Functions.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::Config.3pm
Manifying blib/man3/Nagios::Monitoring::Plugin::ExitResult.3pm
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/check_stuff.t line 5.
BEGIN failed--compilation aborted at t/check_stuff.t line 5.
t/check_stuff.t ..............................
Dubious, test returned 2 (wstat 512, 0x200)
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-01.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-01.t line 4.
t/Nagios-Monitoring-Plugin-01.t ..............
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-02.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-02.t line 4.
t/Nagios-Monitoring-Plugin-02.t ..............
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-03.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-03.t line 4.
t/Nagios-Monitoring-Plugin-03.t ..............
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-04.t line 6.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-04.t line 6.
t/Nagios-Monitoring-Plugin-04.t ..............
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Functions-01.t line 3.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Functions-01.t line 3.
t/Nagios-Monitoring-Plugin-Functions-01.t ....
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Functions-02.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Functions-02.t line 4.
t/Nagios-Monitoring-Plugin-Functions-02.t ....
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Functions-03.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Functions-03.t line 4.
t/Nagios-Monitoring-Plugin-Functions-03.t ....
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Getopt-01.t line 5.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Getopt-01.t line 5.
t/Nagios-Monitoring-Plugin-Getopt-01.t .......
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Getopt-02.t line 5.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Getopt-02.t line 5.
t/Nagios-Monitoring-Plugin-Getopt-02.t .......
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Getopt-03.t line 8.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Getopt-03.t line 8.
t/Nagios-Monitoring-Plugin-Getopt-03.t .......
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Getopt-04.t line 5.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Getopt-04.t line 5.
t/Nagios-Monitoring-Plugin-Getopt-04.t .......
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Performance-02.t line 3.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Performance-02.t line 3.
t/Nagios-Monitoring-Plugin-Performance-02.t ..
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Performance.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Performance.t line 4.
t/Nagios-Monitoring-Plugin-Performance.t .....
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Range.t line 4.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Range.t line 4.
t/Nagios-Monitoring-Plugin-Range.t ...........
No subtests run
Can't locate Test/More.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 .) at t/Nagios-Monitoring-Plugin-Threshold.t line 3.
BEGIN failed--compilation aborted at t/Nagios-Monitoring-Plugin-Threshold.t line 3.
Failed 16/16 test programs. 0/0 subtests failed.
t/Nagios-Monitoring-Plugin-Threshold.t .......
No subtests run
Test Summary Report
t/check_stuff.t (Wstat: 512 Tests: 0 Failed: 0)
Non-zero exit status: 2
Parse errors: No plan found in TAP output
t/Nagios-Monitoring-Plugin-01.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-02.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-03.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-04.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Functions-01.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Functions-02.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Functions-03.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Getopt-01.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Getopt-02.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Getopt-03.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Getopt-04.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Performance-02.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Performance.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Range.t (Wstat: 512 Tests: 0 Failed: 0)
t/Nagios-Monitoring-Plugin-Threshold.t (Wstat: 512 Tests: 0 Failed: 0)
Files=16, Tests=0, 0 wallclock secs ( 0.04 usr 0.01 sys + 0.03 cusr 0.02 csys = 0.10 CPU)
Result: FAIL
make: *** [test_dynamic] Error 2
[root@nagios nagiosxi]# getenforce
Disabled
