Global Event Handler Component
Fred Kroeger
Post by Fred Kroeger »
I've configured a Service State Change Handler in the Global Event Handler component but I have not been able to make it work.
And yes I have enabled the Global event Handler (However Notifications are Disabled)
/usr/local/nagios/local/EventHandlers/Service.sh  "%host%" "%service%"
I have cut it down to an absolute basic script just to prove it
# cat /usr/local/nagios/local/EventHandlers/Service.sh
#!/bin/sh
# Parameters passed by Nagios
# %host%
# %service%
host=${1}
service=${2}
DATE=`/bin/date`
echo $DATE,$host,$service >> /var/log/events/service-event.txt
Nothing ever gets written to the log file
I can run the command manually and it works fine
su - nagios -c "/usr/local/nagios/local/EventHandlers/Service.sh HOST-1 SERVICE-A"
# cat /var/log/events/service-event.txt
Wed Nov 11 16:48:47 WST 2015,HOST-1,SERVICE-A
I'm running NagiosXI 5R2.0
Any ideas .... Fred
Re: Global Event Handler Component
Are these set and un-commented in you nagios.cfg
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
enable_event_handlers=1
Can we also see the following
ls -l /var/log/events/service-event.txt
ls -l /usr/local/nagios/local/EventHandlers/Service.sh
Fred Kroeger
Thanks Scott - yes the global_host_event_handler & global_service_event_handler entries were commented out in nagios.cfg.
Uncommented them and info is now appearing in my events.txt file OK.
Not sure that I recall seeing anywhere that these variables need to be set for the Global Event Handler Component to work ?
The reason we had it commented out was that we were using a 3rd party app from HP that used used the Global Event Handler to send events to HP's BSM product.
I take it these variables can only be defined once ?
Fred Kroeger wrote: I take it these variables can only be defined once ?
Correct. However you could change the command that they refer to to run multiple programs, just concatenate the commands.
Fred Kroeger
Can you give me an example of concatenating the commands please ?
ssax
Dreams In Code
Post by ssax »
You would just edit the command like so:
This run the first command and then the second command regardless of the success of Service.sh:
/usr/local/nagios/local/EventHandlers/Service.sh  "%host%" "%service%"; /your/second/command.sh "%host%" "%service%"
This will run the second command only if the first command is successful:
/usr/local/nagios/local/EventHandlers/Service.sh  "%host%" "%service%" && /your/custom/hp/command "%host%" "%service%"
Fred Kroeger
Brilliant ! Thanks for this - much apppreciated.
You can close this. Regards.... Fred
