Manual Install without Internet access
fkroeger
Post by fkroeger »
I have RHEL 5.5 32b installed on a server that does not have access to the Internet.
Trying to install NagiosXI results in failure as it can't access any of the repo's.
Can anyone supply a list of steps required to install NagiosXI in this environment.
I envisage that I will be downloading the required packages from the repo's to a server that does have internet access and then copying the packages across to the Nagios server.
Thanks...
mmestnik
Re: Manual Install without Internet access
Post by mmestnik »
Our product requires yum and it's repositories to be working and correctly configured. If you'd like you could try and mirror the whole repositories and fake DNS replies. Though using one of these(perhaps more then once) would likely be the way to go.
