Hi all,
i've a little bit problem when i tried to install the Nagios Event log client on one server (Win2k3)
see my attachment below ...
Service seems to be up and running but when i tried to generate a test event, nothing has been notified to Nagios XI server ... maybe have you got an idea about this problem ?
Thx in advance
Bye
Error when installing Nagios Event log client
Re: Error when installing Nagios Event log client
and in application event viewer i've this error
noone can help me ?
i don't understand because on Navlog website creator, i saw that navlog 1.9.2 is fully compatible with W2k3 servers ... maybe i did something wrong ?
Did you try downloading and install the libraries that were included on this site:
https://www.monitoringexchange.org/inve ... agEventLog
Looks like there are some VCredist libraries that may need to be installed, as the error you're getting is relevant to finding libraries.
Nicholas Scott
ok i will do it as soon i'm back at work ...thx you very much
have a nice sunday
Bye
have a nice sunday
Bye
so i already have these same error messages after installed VCredist libraries .. but this time i retreive event in Nagios ... so we can consider that this message are not really important ....
Problem solved from my side ...
Thanks you for your help
Bye
Bye
Heh, thats curious. The error must occur after the it hits the library error.
Nicholas Scott
sorry i'm french and i' don't understant your last answer ...
