how to configure nagios sendmail after installing nagios
sinkak
Post by sinkak »
if i did this step
./configure --with-nagios-group=nagios --with-command-group=nagcmd
and missed to add this at the end
-–with-mail=/usr/sbin/sendmail
is there any way to configure with out re-compile and re-installing everything again.
ssax
Dreams In Code
Re: how to configure nagios sendmail after installing nagios
Post by ssax »
I suppose you could always make /usr/sbin/sendmail a symbolic link to somewhere else.
mv /usr/sbin/sendmail /usr/sbin/sendmail.old
ln -s /your/other/path /usr/sbin/sendmail
sinkak
Re: how to configure nagios mail after installing nagios
Post by sinkak »
In the initial step of nagios configuration.
./configure --with-nagios-group=nagios --with-command-group=nagcmd and missed to add this at the end -–with-mail=/usr/bin/mail or -–with-mail=/usr/sbin/sendmail
I forgot to add mail option to it before i did make install step.
how creating new symbolic link will connect mail to nagios?
i have this in commands.cfg
        command_name    notify-host-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\
nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** WSA $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
        command_name    notify-service-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTAD
DRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mail -s "** WSA $NOTIFICATIONTYPE$ Service Alert: $HOSTA
LIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
The command @ssax posted above should work, what this will do is have Nagios look for your sendmail in the proper location that Nagios defaults to.
sinkak
Post by sinkak »
i am using /usr/bin/mail in commands.cfg
in these steps.
mv  /usr/bin/mail  /usr/bin/mail.old
ln -s /your/other/path  /usr/bin/mail
what is /your/other/path
It is the source path that you're looking to link your sendmail from to the /usr/bin/mail.
sinkak
Post by sinkak »
i am not using send mail. i am using /usr/bin/mail in commands.cfg
Where is your sendmail configured at on your system?
sinkak
Post by sinkak »
i have not configured sendMail on my nagios server.
i am using only /usr/bin/mail. which i forgot to add in the nagios configuration step.
i just used it as an example to ask if i forgot to add sendmail or mail in configuration step before make install. how do you configure it later.
Can you run the command and post the output -
/usr/bin/mail -V
