I need to update my mrtg.conf file to reflect an interface change so that the rrd files are updated. I cannot seem to find the proper mrtg.conf file to update seems like the structure has changed ? In the attached example the _654 is now _684
We used to be able to manually change the mrtg.conf file
router interface update no performance data
Re: router interface update no performance data
looks like they are in /etc/mrtg/conf.d should be good now
Yea, we went from using one big MRTG config file to splitting them up and sticking them in the conf.d folder.
I'll close this up.
I'll close this up.
