WebInject problem
WebInject problem
(No output on stdout) stderr: Can't locate XML/Simple.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./webinject.pl line 24.
That problem start when I follow that guide to enable VMware. https://assets.nagios.com/downloads/nag ... ios-XI.pdf
I think the part about remove perl-xml and reinstall it for VMware broke something.
Can you help me to fix that please.
Nagios XI Installation Profile
System:
Nagios XI Version : 5.2.2
sldmon0139 3.10.0-229.14.1.el7.x86_64 x86_64
Red Hat Enterprise Linux Server release 7.1 (Maipo)
Gnome is not installed
Apache Information
PHP Version: 5.4.16
Agent: Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/46.0.2490.86 Safari/537.36
Server Name: sldmon0139.saq.qc.ca
Server Address: 172.26.14.229
Server Port: 80
Date/Time
PHP Timezone: US/Eastern
PHP Time: Thu, 19 Nov 2015 17:03:16 -0500
System Time: Thu, 19 Nov 2015 17:03:16 -0500
Nagios XI Data
License ends in:
Days left in Trial: 38
nagios (pid 7684) is running...
NPCD running (pid 24186).
ndo2db (pid 24113) is running...
CPU Load 15: 0.60
Total Hosts: 101
Total Services: 323
Function 'get_base_uri' returns: http://sldmon0139.saq.qc.ca/nagiosxi/
Function 'get_base_url' returns: http://sldmon0139.saq.qc.ca/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://sldmon0139.saq.qc.ca/nagiosxi/in ... rofile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.039 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.043 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.044 ms
--- localhost ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2004ms
rtt min/avg/max/mdev = 0.039/0.042/0.044/0.002 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2015-11-19 17:03:18-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... connected.
Length: unspecified [text/html]
Saving to: '/usr/local/nagiosxi/tmp/ccm_index.tmp'
0K .......... 988K=0.01s
2015-11-19 17:03:18 (988 KB/s) - '/usr/local/nagiosxi/tmp/ccm_index.tmp' saved [10946]
Network Settings
1: lo: mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno16780032: mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:50:56:8c:07:28 brd ff:ff:ff:ff:ff:ff
inet 172.26.14.229/24 brd 172.26.14.255 scope global eno16780032
inet6 fe80::250:56ff:fe8c:728/64 scope link
default via 172.26.14.1 dev eno16780032 proto static metric 100
172.26.14.0/24 dev eno16780032 proto kernel scope link src 172.26.14.229 metric 100
System:
Apache Information
PHP Version: 5.4.16
Server Port: 80
Date/Time
Nagios XI Data
License ends in:
CPU Load 15: 0.60
Total Hosts: 101
Total Services: 323
Ping Test localhost
Running:
Running:
Network Settings
Re: WebInject problem
I just tried to replicate this and didn't see an issue.
What is the result when you run -
yum install perl-XML-SAX --exclude=perl-XML-SAX-Base -y
[root@sldlog0261 data]# yum install perl-XML-SAX --exclude=perl-XML-SAX-Base -y
Loaded plugins: langpacks, product-id, rhnplugin, subscription-manager
This system is receiving updates from RHN Classic or Red Hat Satellite.
Resolving Dependencies
--> Running transaction check
---> Package perl-XML-SAX.noarch 0:0.99-9.el7 will be installed
--> Processing Dependency: perl(LWP::UserAgent) for package: perl-XML-SAX-0.99-9.el7.noarch
--> Processing Dependency: perl(XML::SAX::Base) for package: perl-XML-SAX-0.99-9.el7.noarch
--> Processing Dependency: perl(XML::NamespaceSupport) for package: perl-XML-SAX-0.99-9.el7.noarch
--> Processing Dependency: perl(XML::SAX::Exception) for package: perl-XML-SAX-0.99-9.el7.noarch
---> Package perl-XML-NamespaceSupport.noarch 0:1.11-10.el7 will be installed
---> Package perl-libwww-perl.noarch 0:6.05-2.el7 will be installed
--> Processing Dependency: perl(Net::HTTP) >= 6.04 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(WWW::RobotRules) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Daemon) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Request::Common) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(File::Listing) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Cookies) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Negotiate) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(LWP::MediaTypes) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Request) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Date) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Response) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Status) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(URI) >= 1.10 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(Encode::Locale) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTML::HeadParser) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(URI::Heuristic) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTML::Entities) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(Digest::MD5) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(URI::Escape) for package: perl-libwww-perl-6.05-2.el7.noarch
---> Package perl-Digest-MD5.x86_64 0:2.52-3.el7 will be installed
--> Processing Dependency: perl(Digest::base) >= 1.00 for package: perl-Digest-MD5-2.52-3.el7.x86_64
---> Package perl-Encode-Locale.noarch 0:1.03-5.el7 will be installed
---> Package perl-File-Listing.noarch 0:6.04-7.el7 will be installed
---> Package perl-HTML-Parser.x86_64 0:3.71-4.el7 will be installed
--> Processing Dependency: perl(HTML::Tagset) >= 3 for package: perl-HTML-Parser-3.71-4.el7.x86_64
---> Package perl-HTTP-Cookies.noarch 0:6.01-5.el7 will be installed
---> Package perl-HTTP-Daemon.noarch 0:6.01-5.el7 will be installed
---> Package perl-HTTP-Date.noarch 0:6.02-8.el7 will be installed
--> Processing Dependency: perl(Time::Zone) for package: perl-HTTP-Date-6.02-8.el7.noarch
---> Package perl-HTTP-Message.noarch 0:6.06-6.el7 will be installed
--> Processing Dependency: perl(IO::Uncompress::Bunzip2) >= 2.021 for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Compress::Bzip2) >= 2.021 for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Uncompress::RawInflate) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Compress::Gzip) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Compress::Deflate) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::HTML) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Uncompress::Inflate) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::Uncompress::Gunzip) for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(Compress::Raw::Zlib) for package: perl-HTTP-Message-6.06-6.el7.noarch
---> Package perl-HTTP-Negotiate.noarch 0:6.01-5.el7 will be installed
---> Package perl-LWP-MediaTypes.noarch 0:6.02-2.el7 will be installed
---> Package perl-Net-HTTP.noarch 0:6.06-2.el7 will be installed
--> Processing Dependency: perl(IO::Socket::SSL) >= 1.38 for package: perl-Net-HTTP-6.06-2.el7.noarch
---> Package perl-URI.noarch 0:1.60-9.el7 will be installed
--> Processing Dependency: perl(Business::ISBN) for package: perl-URI-1.60-9.el7.noarch
---> Package perl-WWW-RobotRules.noarch 0:6.02-5.el7 will be installed
---> Package perl-Business-ISBN.noarch 0:2.06-2.el7 will be installed
--> Processing Dependency: perl(Business::ISBN::Data) >= 20120719.001 for package: perl-Business-ISBN-2.06-2.el7.noarch
---> Package perl-Compress-Raw-Zlib.x86_64 1:2.061-4.el7 will be installed
---> Package perl-Digest.noarch 0:1.17-245.el7 will be installed
---> Package perl-HTML-Tagset.noarch 0:3.20-15.el7 will be installed
---> Package perl-IO-Compress.noarch 0:2.061-2.el7 will be installed
--> Processing Dependency: perl(Compress::Raw::Bzip2) >= 2.061 for package: perl-IO-Compress-2.061-2.el7.noarch
---> Package perl-IO-HTML.noarch 0:1.00-2.el7 will be installed
---> Package perl-IO-Socket-SSL.noarch 0:1.94-3.el7 will be installed
--> Processing Dependency: perl(IO::Socket::IP) >= 0.20 for package: perl-IO-Socket-SSL-1.94-3.el7.noarch
--> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL-1.94-3.el7.noarch
--> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.94-3.el7.noarch
--> Processing Dependency: perl(Net::SSLeay) for package: perl-IO-Socket-SSL-1.94-3.el7.noarch
---> Package perl-TimeDate.noarch 1:2.30-2.el7 will be installed
---> Package perl-Business-ISBN-Data.noarch 0:20120719.001-2.el7 will be installed
---> Package perl-Compress-Raw-Bzip2.x86_64 0:2.061-3.el7 will be installed
---> Package perl-IO-Socket-IP.noarch 0:0.21-4.el7 will be installed
---> Package perl-Net-LibIDN.x86_64 0:0.12-15.el7 will be installed
---> Package perl-Net-SSLeay.x86_64 0:1.55-3.el7 will be installed
Error: Package: perl-XML-SAX-0.99-9.el7.noarch (non-production-rhel-x86_64-server-7-new)
Requires: perl(XML::SAX::Base)
Requires: perl(XML::SAX::Exception)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
We are using Redhat Satellite to deploy our server.
We also use proxy to get package from the repo you add when I run the ./fullinstall script from the install media.
[root@sldlog0261 data]# yum repolist
repo id repo name status
epel/x86_64 Extra Packages for Enterprise Linux 7 - x86_64 8,836
non-prd_saq_custom-7-new non-prd_saq_custom-7-new 7
non-production-rhel-x86_64-server-7-new non-production-rhel-x86_64-server-7-new 7,728
non-production-rhel-x86_64-server-extras-7-new non-production-rhel-x86_64-server-extras-7-new 125
non-production-rhel-x86_64-server-optional-7-new non-production-rhel-x86_64-server-optional-7-new 6,154
non-production-rhel-x86_64-server-supplementary-7-new non-production-rhel-x86_64-server-supplementary-7-new 71
non-production-rhn-tools-rhel-x86_64-server-7-new non-production-rhn-tools-rhel-x86_64-server-7-new 76
repolist: 22,997
Do you think I have to exclude those repo ?
repolist: 22,997
I think those repo's are what is causing the issue. Are you able to use the standard repo list for this rather than a modified one? You may experience other issues because of this.
Here's a quick output of how a standard system looks on my end -
base CentOS-6 - Base 6,575
cr CentOS-6 - CR 0
epel Extra Packages for Enterprise Linux 6 - x86_64 11,866
extras CentOS-6 - Extras 45
nagios-base Nagios 151
nagiosxi-deps Nagios XI Dependencies 33
rpmforge RHEL 6 - RPMforge.net - dag 4,718
updates CentOS-6 - Updates 670
repolist: 24,058
The error is related to this being missing:
But the failure of the install command looks like it's the repos like rkennedy said.
yum install perl-XML-SimpleRe: WebInject problem
I run
Now the problem is fix.
I think something remove that package. Dependency problem ...
Thank you!
yum install perl-XML-SimpleI think something remove that package. Dependency problem ...
Thank you!
Glad to see this worked! I will now close this thread out, but feel free to open another if you ever need assistance in the future.
We are using RHEL7 with Redhat Satellite. Our repo is the clone of the original RHEL. The only difference is the time we sync it. That is not the problem cause.rkennedy wrote:I think those repo's are what is causing the issue. Are you able to use the standard repo list for this rather than a modified one? You may experience other issues because of this.
Here's a quick output of how a standard system looks on my end -Code: Select all
repo id repo name status base CentOS-6 - Base 6,575 cr CentOS-6 - CR 0 epel Extra Packages for Enterprise Linux 6 - x86_64 11,866 extras CentOS-6 - Extras 45 nagios-base Nagios 151 nagiosxi-deps Nagios XI Dependencies 33 rpmforge RHEL 6 - RPMforge.net - dag 4,718 updates CentOS-6 - Updates 670 repolist: 24,058
Thx!
