See my prior post XI https://support.nagios.com/forum/viewto ... 87#p161687 for background...
I did a LOT of debugging/testing. It turns out... that if you set result_worker=(# != 1) in the mod_gearman_neb.conf... the nagios process crashes with the - Caught SIGSEGV, shutting down... message previously pointed out...
So... seems that there's a BUG somewhere.
XI Post Upgrade (5.2.2) Monitoring Engine (nagios) Part II
Re: XI Post Upgrade (5.2.2) Monitoring Engine (nagios) Part
Thank you for posting this, our developer is aware of this but we're not sure why having result_worker greater than 1 is causing the nagios process to segfault but we do see that it is likely instructions inside the mod_gearman module that is causing it. Unfortunately, mod_gearman is a 3rd party piece of software and we don't really have any control over their code/product. We have been in contact with the mod_gearman developers and they said they haven't see it before. We'll do what we can.
larrydhelms
Does the problem exist with Nagios 2014 (aka Version 4) as well or is this limited to Version 5.x?
Is there a work-around (other than - NOT using mod_gearman; cause we have a distributed environment (aka only certain workers can perform certain task due to network connectivity/permissions)?
Is there an ETF (estimated time to fix)?
The problem does exist in 2014, the workaround is to set result_worker to 1 as you found out, we're not sure why it works for some people and not others or why it just starts happening:
https://labs.consol.de/nagios/mod-gearman/index.html
I'm unable to give an ETA/ETF, the developers are aware of it though.
Taken from here:result_workers
Number of result worker threads. Usually one is enough. You may increase the value if your result queue is not processed fast enough.
