Manually add services in Metrics
sarfarosh
Post by sarfarosh »
Hello Team,
We have added custom scripts to monitor Temperature, CPU, Memory of network devices (Router & Switches), we need to add a view on Dashboard for Top 10 Memory, CPU usage, Temperature for these devices. But we are not able to get that through Metrics on Home Page.
Can you please help me in achieving this.
Re: Manually add services in Metrics
We do have an internal feature request in place for adding custom command names / metric types in the "Metrics" component (task_id=6507). I don't have an ETA on that though. In fact, it is still pending approval.
What is the Nagios XI and the "Metrics" component version that you are currently using? Can you show us an example command that you are using?
sarfarosh
Post by sarfarosh »
Hi Team,
Do you have any update on this Feature. All our customers are asking for this feature.
Regards
Sarfaraz
Post by mcapra »
There was some work done on this functionality, but it's going to require a full re-write of the Metrics component. The task is still pending.
