No such instance currently exists at this OID
Santoshthakur
Post by Santoshthakur »
When I am executing command snmpget-v2c -cpassword hostname memTotalSwap, I am getting below error.
UCD-SNM-PMIB::No such instance currently exists at this OID
Could you please help me to resolve this issue.
And I am giving same error for other OIDs as well like TCP connection, CPU, network interfaces etc.
I can see MIB text files in my system. So, is there any configuration required, so that above command is properly executed.
Your suggestion is highly appreciated. Thanks.
jrdalrymple
Re: No such instance currently exists at this OID
Post by jrdalrymple »
What type of system is hostname? Not all snmp agents have UCD-SNMP-MIB OIDs installed. If you ran this against a Cisco switch for example you can be rest assured you'd get the error you're seeing.
If this is a Linux system (which is my assumption) do 2 things:
1) snmpwalk the entire tree:
snmpwalk -v2c -c <community string> hostname
2) share with us a sanitized copy of snmpd.conf
What happens if you run the check command using the OID rather than the MIB?
