I have downloaded NagiosXI trial OVA (5.2.2) and have wanted to trial it as an upgrade from our current install at work.
Unfortunately, I have come unstuck at the first hurdle and am not sure what I may be doing wrong. I have searched the forums for this but could not find anyone else having the same issue with the current version.
So when I come to configure the AD Integration as:
Enabled This Authentication server
Connection Method: Active Directory
Base DN: DC=AS,DC=local (internally we use as.local)
Account suffix: AS.local
Domain Controllers: ad3.as.local
Security: None
pic attached
Now when I come to use the above settings and perform a Import of Users using my domain admin account (or any account) I get the following:
Unable to authenticate: 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, veceI have tried the following:
- Making sure that the AD server can be pinged from NagiosXI command interface
- Made sure that the correct IP address is picked up by DNS and can be pinged from NagiosXI
- Made sure to change the DNS entry for the AD server to IP address
- Tried to use alternative live domain admin accounts
- Tried to configure LDAP by using DNS and IP address for the LDAP Host, and 389 for the port
and no matter what I do I get the same error message as above. Would you be able to help me identify what I may be doing wrong.
The virtual NagiosXI is on the same VLAN as the AD server and in fact it is sitting on the same VMware host and has access to the same vSwitch. I have made sure to power cycle the NagiosXI server.
Can you please help me identify where I am going wrong.
Thank you,
