Error: Service check command 'check_load' specified in service 'CPU Load for host 'ora_linux7' not defined anywhere!Code: Select all
find / -name commands.cfgCode: Select all
# COMMANDS.CFG - SAMPLE COMMAND DEFINITIONS FOR NAGIOS 4.1.1
# NOTES: This config file provides you with some example command definitions
# that you can reference in host, service, and contact definitions.
# You don't need to keep commands in a separate file from your other
# object definitions. This has been done just to make things easier to
# understand.
# SAMPLE NOTIFICATION COMMANDS
# These are some example notification commands. They may or may not work on
# your system without modification. As an example, some systems will require
# you to use "/usr/bin/mailx" instead of "/usr/bin/mail" in the commands below.
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
# SAMPLE HOST CHECK COMMANDS
# This command checks to see if a host is "alive" by pinging it
# The check must result in a 100% packet loss or 5 second (5000ms) round trip
# average time to produce a critical error.
# Note: Five ICMP echo packets are sent (determined by the '-p 5' argument)
# 'check-host-alive' command definition
command_name check-host-alive
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# 'check_local_users' command definition
command_name check_local_users
command_line $USER1$/check_users -w $ARG1$ -c $ARG2$
# 'check_local_swap' command definition
command_name check_local_swap
command_line $USER1$/check_swap -w $ARG1$ -c $ARG2$
# 'check_local_mrtgtraf' command definition
command_name check_local_mrtgtraf
command_line $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
# NOTE: The following 'check_...' commands are used to monitor services on
# both local and remote hosts.
# 'check_ftp' command definition
command_name check_ftp
command_line $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
# 'check_hpjd' command definition
command_name check_hpjd
command_line $USER1$/check_hpjd -H $HOSTADDRESS$ $ARG1$
# 'check_snmp' command definition
command_name check_snmp
command_line $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
# 'check_http' command definition
command_name check_http
command_line $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
# 'check_ssh' command definition
command_name check_ssh
command_line $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
# 'check_dhcp' command definition
command_name check_dhcp
command_line $USER1$/check_dhcp $ARG1$
# 'check_ping' command definition
command_name check_ping
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
# 'check_pop' command definition
command_name check_pop
command_line $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
# 'check_imap' command definition
command_name check_imap
command_line $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
# 'check_smtp' command definition
command_name check_smtp
command_line $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
# 'check_tcp' command definition
command_name check_tcp
command_line $USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
# 'check_udp' command definition
command_name check_udp
command_line $USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
# SAMPLE PERFORMANCE DATA COMMANDS
# These are sample performance data commands that can be used to send performance
# data output to two text files (one for hosts, another for services). If you
# plan on simply writing performance data out to a file, consider using the
# host_perfdata_file and service_perfdata_file options in the main config file.
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /usr/local/nagios/var/host-perfdata.out
# 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /usr/local/nagios/var/service-perfdata.out
# SAMPLE SERVICE CHECK COMMANDS
# These are some example service check commands. They may or may not work on
# your system, as they must be modified for your plugins. See the HTML
# documentation on the plugins for examples of how to configure command definitions.
# NOTE: The following 'check_local_...' functions are designed to monitor
# various metrics on the host that Nagios is running on (i.e. this one).
# 'check_local_disk' command definition
command_name check_local_disk
command_line $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
# 'check_local_load' command definition
command_name check_local_load
command_line $USER1$/check_load -w $ARG1$ -c $ARG2$
# 'check_local_procs' command definition
command_name check_local_procs
hsmith wrote:What is the output of a grep check_nrpe /path/to/commands.cfg command?
[root@nagios ~]# grep check_nrpe /usr/local/nagios/etc/objects/command.cfg
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
[root@nagios ~]#
