Linux NRPE: unable to read output
dlukinski
Post by dlukinski »
Used wizard-based configuration for Linux-client monitoring (works for my CentOS)
Last login: Wed Nov 25 17:06:51 2015
[root@fikc-nagxidev01 ~]# /usr/local/nagios/libexec/check_nrpe -H 10.x.x.28
NRPE v2.15
[root@fikc-nagxidev01 ~]# /usr/local/nagios/libexec/check_nrpe -H 10.x.x.28 -t 30 -c check_cpu_stats -a '-w 85 -c 95'
NRPE: Unable to read output (same issue with CPU stats, processes, Memory, Open Files, Yum, etc..)
OS is possibly RedHat EL 6.5 (have no direct access to it)
What to check next?
Re: Linux NRPE: unable to read output
Post by Box293 »
Please read through this guide as it should address your issue:
https://assets.nagios.com/downloads/nag ... utions.pdf
If this doesn't fix your problem, please let us know what you tried (including commands typed) and what the output/result is.
raamardhani7
Post by raamardhani7 »
Please check in the nrpe.cfg file in the remote server, whether you have defined the parameters in it. If possible, please post your nrpe.cfg file.
dlukinski
Post by dlukinski »
raamardhani7 wrote:Please check in the nrpe.cfg file in the remote server, whether you have defined the parameters in it. If possible, please post your nrpe.cfg file.
dlukinski
Post by dlukinski »
raamardhani7
dlukinski wrote:
Please define the command in the nrpe.cfg
command[check_cpu_stats]=/usr/local/nagios/libexec/check_cpu_stats $ARG1$
Agrument1 I defined as -w <warning threshold> -c <Critical threshold>
Similarly for the other parameters add them in nrpe.cfg file. Once done execute the below command.
service xinetd restart
Post by Box293 »
Make sure that these have not been defined in the /usr/local/nagios/etc/nrpe/common.cfg file already.
Box293 wrote:Please read through this guide as it should address your issue:
It would be good to see what testing you have tried.
dlukinski
Post by dlukinski »
Took some time to get my hand on another RHEL 6.5 system, which exhibits same behaviour:
After NRPE client install (per XI manual), "CPU Stats", "Memory Usage", "Open Files" and processes such as Java are not operational. (now same for 2 x RHEL EL 6.5)
- so to me this is NRPE client out of the box behaviour on this Linux platform.
- CPU check is defined in common.cfg (attached)
How to overcome this (we have MANY RHEL installs - they might all work same way if we try NRPE installs now)?
hsmith
Agent Smith
Post by hsmith »
Did you install NRPE manually, and compile it youself, or did you run the fullinstall script?
Former Nagios Employee.
me.
dlukinski
Post by dlukinski »
hsmith wrote:Did you install NRPE manually, and compile it youself, or did you run the fullinstall script?
we ran fullinstall script in both cases (same results with many checks missing)
