Hi Team,
My Current project wants us to monitor weblogic & iplanet.
Environment is not standalone, it is HA. (Active-Passive node).
Requirement: They have both active and passive nodes and they want us to monitor Active nodes all the time . Whenever there is a failover happens, Passive node will be coming up and we need to monitor this node which is up. Gist, it is active-passive setup. Could you please suggest us what to be done in this scenario, any documentation/links available will be of much help, thanks.
Regards,
Ram.
How to Setup HA for Applications
- Box293
- Too Basu
Re: How to Setup HA for Applications
Here is our guide on WebLogic:
I could not find anything on the Nagios Exchange called iplanet. Does it have any other names?
raamardhani7
Thank you so much for the update Box.Box293 wrote:Here is our guide on WebLogic:
Could you please help me with the below concern of mine.
Requirement: They have both active and passive nodes and they want us to monitor Active nodes all the time . Whenever there is a failover happens, Passive node will be coming up and we need to monitor this node which is up. Gist, it is active-passive setup. Could you please suggest us what to be done in this scenario.
- Box293
- Too Basu
You are most likely going to need to monitor both nodes all the time. Perhaps there is a check to report which node is the active one.
Nagios just "monitors stuff". It doesn't really know about active-passive nodes. It is up to the plugins to handle that. If the webinject plugin does not handle active-passive modes then you may have to contact the developer of the plugin and see what they can suggest.
raamardhani7
Hi Box293,Box293 wrote:You are most likely going to need to monitor both nodes all the time. Perhaps there is a check to report which node is the active one.
Thanks for the update, you can close this thread. thanks a lot..
