I have a custom Apache configuration file:
<VirtualHost *:80>
ServerName outsideit.net
DirectoryIndex index.html index.php
DocumentRoot /var/www/outsideit.net/public_html
LogLevel warn
ErrorLog /var/www/outsideit.net/log/error.log
CustomLog /var/www/outsideit.net/log/access.log combined
<Directory "/usr/local/nagiosxi/html">
Options None
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
Require all granted
# Redirect permanent / https://outsideit.net/
</Directory>
Options ExecCGI
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
AuthName "Nagios Core"
AuthType Basic
AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
Require valid-user
Require all denied
</Directory>
<Directory "/usr/local/nagios/share">
Options None
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
AuthType Basic
Require valid-user
Require all denied
</Directory>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile path
SSLCertificateKeyFile path
SSLCertificateChainFile path
Servername outsideit.net
SSLProtocol -All +TLSv1.2
# SSLCipherSuite HIGH:MEDIUM:!aNULL:!MD5
SSLHonorCipherOrder On
SSLCipherSuite ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
LogLevel warn
Options None
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
Require all granted
</Directory>
Options ExecCGI
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
AuthType Basic
Require valid-user
Require all denied
</Directory>
Options None
AllowOverride None
Order deny,allow
Deny from all
Allow from xxxxx
AuthType Basic
Require valid-user
Require all denied
</Directory>
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
</VirtualHost>
Alias /nagiosxi "/usr/local/nagiosxi/html"
Alias /nagios "/usr/local/nagios/share"
It doesn't work with or without ssl. I know this is a not supported configuration but if I could get some advice how to troubleshoot this, I'm a bit stuck atm. Apart from those two dashlets everyhting seems to be working normally. I don't see any errors in the Apache errorlog, nor in the developer console.
EDIT: The apply configuration is also acting a bit weird. The apply configuration windows just keeps going:
Waiting for configuration verification........................................................................................................................................................................................................................Code: Select all
Checking misc settings...
Total Warnings: 50
Total Errors: 0
RET: 0
OUTPUT=RET: 0
RETURNCODE=0
