Help error Critical connection refused
Arthur
Post by Arthur »
Hello im new here but i have a problem while adding windows server to be monitorized by nagios it appears this error
connect to address xxxxx and port 12489:
conection refused
Please i need help because i don´t know how to fix it
Re: Help error Critical connection refused
Post by Box293 »
Do you have NSClient++ installed on your Windows server?
Does the Windows firewall allow port 12489?
Does your nsc.ini or nsclient.ini allow the IP address of your Nagios server? These files are in C:\Program Files\NSClient++\
This guide explains it (even though it is for Nagios XI):
And so does this one:
https://assets.nagios.com/downloads/nag ... ndows.html
