Test internet connection failed Cisco router 800 series
ahmedbarbary
Post by ahmedbarbary »
I have mail server using to send and receive emails in server only mode
and i use router Cisco 800 series as gateway to mail server
inside my network
mail server take ip 192.168.1.4
router cisco 192.168.1.254
public ip for mail server is 78.93.244.61 and port 25 is open in it
i do nat from outside public ip 78.93.244.61 to inside local netork mail server 192.168.1.4
but no access for internet to mail server
I check every thing in my network every thing is ok
but remaining i not check cisco router 800 series config file
config file as following :
xxxx#sh run
Building configuration...
Current configuration : 4660 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname xxxxx
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone KSA 3
crypto pki trustpoint TP-self-signed-xxxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-164429193
revocation-check none
rsakeypair TP-self-signed-xxxx
dot11 syslog
dot11 ssid xxxx
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 xxxx
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.11.1
ip dhcp pool wireless
import all
network 10.10.11.0 255.255.255.0
default-router 10.10.11.1
dns-server 212.93.192.4 212.93.192.5
lease 0 2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name awalnet.net.sa
ip name-server 84.22.224.11
ip name-server 84.22.224.12
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group xxx
key xxx
dns 212.93.192.4 212.93.192.5
include-local-lan
dhcp server 10.10.10.1
max-users 10
netmask 255.255.255.0
crypto xxx profile sdm-ike-profile-1223
match identity group xxx
client authentication list sdm_vpn_xauth_ml_2
isakmp authorization list sdm_vpn_group_ml_1
client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set security-association idle-time 60
set transform-set xxxxx
set isakmp-profile sdm-ike-profile-1
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template1 type tunnel
ip unnumbered Dialer0
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid xxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $xxxxxx$
ip address 78.93.244.61 255.255.255.252 secondary
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxx.xx password xxxxx
interface BVI1
ip address 10.10.11.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.4 25 78.93.244.61 25 extendable
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 10.10.11.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 23 permit 212.93.196.0 0.0.0.255
access-list 23 permit 212.93.192.0 0.0.0.255
access-list 23 permit 212.93.193.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 23 permit 212.93.208.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community private RW
snmp-server community public RO
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Are there are any thing wrong in config file delay or stop internet connection to mail server
please help me
hsmith
Agent Smith
Re: Test internet connection failed Cisco router 800 series
Post by hsmith »
I'm sorry but I have to ask the obvious question here: Is there anything we can help you with configuring that is Nagios related? Configuring your router is out of scope for this forum.
Former Nagios Employee.
me.
