XI Upgrade failure using RDS
Does the UI upgrade use a default password for MySQL? I'm using AWS RDS and I am receiving the error "Error backing up MySQL database 'nagiosql' - check the password in this script!". It's really poor practice to use default passwords in RDS, so is there somewhere I can set that in Nagios so the script will run?
Re: XI Upgrade failure using RDS
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up MySQL databases...
mysqldump: Got error: 2005: "Unknown MySQL server host 'nagiosql.*********.us-east-1.rds.amazonaws.com:3306' (0)" when trying to connect
You shouldn't run into an issue if you run the manual upgrade but that's because the manual upgrade doesn't take a backup first.
Run a manual backup and see if that allows it to complete and let us know so we can dig further.
The manual upgrade failed as well.
kernel.shmall = 268435456
kernel.msgmni = 256000
Removing depricated failure_prediction_enabled from NagiosQL
ERROR 2005 (HY000): Unknown MySQL server host 'nagiosql.**********.us-east-1.rds.amazonaws.com:3306' (0)
- Box293
- Too Basu
Can you go to Admin > System Config > Manage System Config
What is in your "Program URL" and "External URL" fields?
Does you Program URL resolve to an internal IP address?
The Program URL is our internal AWS address and External URL is blank.
From your XI machine, can you run the following and post the output -
Replace the ******* accordingly to match the exact hostname that sql is looking for.
Also, please post the output of -
nslookup nagiosql.*********.us-east-1.rds.amazonaws.com
cat /etc/hosts
