NRPE Command Not Defined
jnoble921
Post by jnoble921 »
Nagios Core: 4.1.1
NRPE Client Verison: NRPE v2.15
Both server and client have CentOS 7 Core installed
I am not able to add new commands to check my NRPE client. I keep getting NRPE: Command 'check_uptime' not defined
From my Nagios server I am testing this by running /usr/local/nagios/libexec/check_nrpe -H <MY HOST> -c check_uptime
However some commands work like, but only the "hard coded" commands. I enabled dont_blame_nrpe = 1
/usr/local/nagios/libexec/check_nrpe -H <MY HOST> -c check_total_procs
/usr/local/nagios/libexec/check_nrpe -H <MY HOST> -c check_users
The check_total_procs will not let me change the warning or cirtical threshold however.
I think that I have added the command to my client, /usr/local/nagios/etc/nrpe.cfg
command[check_uptime]=/usr/local/nagios/libexec/check_uptime
I do not know if this is of any help but this is the guide that I followed. http://www.tecmint.com/how-to-add-linux ... ng-server/
I am sure that I am missing something simple and that this gets asked a lot but I would really appreciate any help. Please let me know if there is other information that I can provide.
hsmith
Agent Smith
Re: NRPE Command Not Defined
Post by hsmith »
What method did you use to install NRPE?
find / -name common.cfg -exec cat {} \;
Former Nagios Employee.
me.
jnoble921
Post by jnoble921 »
I found the tutorial at http://www.tecmint.com/how-to-add-linux ... ng-server/, if that is what you mean by method. Please let me know if that is not and I will try and help.
I ran the command you posted on both my server and client. Below is the return on my client. There was no return on my server.
find: ‘/run/user/1000/gvfs’: Permission denied
### GENERIC SERVICES ###
command[check_init_service]=sudo /usr/local/nagios/libexec/check_init_service $ARG1$
command[check_services]=/usr/local/nagios/libexec/check_services -p $ARG1$
### MISC SYSTEM METRICS ###
#command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10
command[check_users]=/usr/local/nagios/libexec/check_users $ARG1$
command[check_load]=/usr/local/nagios/libexec/check_load $ARG1$
command[check_swap]=/usr/local/nagios/libexec/check_swap $ARG1$
command[check_cpu_stats]=/usr/local/nagios/libexec/check_cpu_stats.sh $ARG1$
command[check_mem]=/usr/local/nagios/libexec/custom_check_mem -n $ARG1$
### SYSTEM UPDATES ###
command[check_yum]=/usr/local/nagios/libexec/check_yum
command[check_apt]=/usr/local/nagios/libexec/check_apt
### DISK ###
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
command[check_ide_smart]=/usr/local/nagios/libexec/check_ide_smart $ARG1$
### PROCESSES ###
command[check_all_procs]=/usr/local/nagios/libexec/custom_check_procs
command[check_procs]=/usr/local/nagios/libexec/check_procs $ARG1$
### OPEN FILES ###
command[check_open_files]=/usr/local/nagios/libexec/check_open_files.pl $ARG1$
### NETWORK CONNECTIONS ###
command[check_netstat]=/usr/local/nagios/libexec/check_netstat.pl -p $ARG1$ $ARG2$
### DISK ###
### PROCESSES ###
### OPEN FILES ###
Thank you so much for replying!
hsmith
Agent Smith
Post by hsmith »
Server should not have had an output, so that is good. Can you try some of the commands listed in that common.cfg and see if they work?
me.
jnoble921
Post by jnoble921 »
hsmith wrote:Server should not have had an output, so that is good. Can you try some of the commands listed in that common.cfg and see if they work?
I am sorry, I am not sure what you mean. If I run those commands from my client they seem to work fine like, /usr/local/nagios/libexec/check_yum, OS is up to date. check_uptime etc
However once I check them from server that is where the issue appears to be.
Please let me know what I can do to help more diagnose this! Thank you so much.
hsmith
Agent Smith
Post by hsmith »
From the server, if you run /usr/local/nagios/libexec/check_nrpe -H <your host> -c check_yum for example, does it return anything?
How about this scenario? su to the nagios user, and try to run the plugin locally.
me.
jnoble921
Post by jnoble921 »
hsmith wrote:From the server, if you run /usr/local/nagios/libexec/check_nrpe -H <your host> -c check_yum for example, does it return anything?
From the monitoring server that is running "nagios"
su nagios
[nagios@nagios /]$ /usr/local/nagios/libexec/check_nrpe -H 192.168.1.52 -c check_yum
NRPE: Command 'check_yum' not defined
Some stuff does work
[nagios@nagios /]$ /usr/local/nagios/libexec/check_nrpe -H 192.168.1.52 -c check_total_procs
PROCS CRITICAL: 215 processes | procs=215;150;200;0;
I am sorry EDIT
From the machine that I want to monitor
[nagios@localhost jnoble]$ /usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -c check_yum
hsmith
Agent Smith
Post by hsmith »
What are the permissions of /usr/local/nagios/etc/nrpe/common.cfg?
ls -l /usr/local/nagios/etc/nrpe
edit:
Try this command on the machine you want to monitor
Like you did in the previous post. Leave check_nrpe out of it for now, if that makes sense.
me.
jnoble921
Post by jnoble921 »
hsmith wrote:What are the permissions of /usr/local/nagios/etc/nrpe/common.cfg?
edit:
[[email protected] jnoble]$ ls -l /usr/local/nagios/etc/nrpe
total 8
-rw-r--r--. 1 nagios nagios  687 Nov 16 14:10 asterisk.cfg
-rw-r--r--. 1 nagios nagios 1309 Nov 16 14:10 common.cfg
[[email protected] jnoble]$ /usr/local/nagios/libexec/check_yum
YUM OK:  O/S is up to date.
192.168.1.52 is the server that I want to monitor
192.168.1.54 OR nagios is my main server
Information that may have been helpful sooner but I wanted to make sure that is clear maybe
On the 192.168.1.52 box, run:
service xinetd restart
On the 192.168.1.54 box, run:
and show the output.
Also, post the entire nrpe.cfg and common.cfg file.
