Self created check - wrong info
Anton @ CPB
Post by Anton @ CPB »
Hi
I created to check a MySQL instance. The check runs fine within libexec.
root@nagios:/usr/local/nagios/libexec# ./check_nprobe_mysql
OK - The times are 59 sec apart
But not with the check running - See attached png
Herewith the check_nprobe_mysql code
#!/bin/bash
#Get the date & times from the system and mysql nprobe mysql db
mdatetime=$(date +"%Y-%m-%d %H:%M:%S")
nprobeDateTime=$(mysql --login-path=remote -e "select from_unixtime(FIRST_SWITCHED) from nprobe.flowsflows order by from_unixtime(FIRST_SWITCHED) desc limit 1;" | cut -d')' -f2)
#Convert the dates & time to seconds
systemt=$(date -d "$mdatetime" +%s)
nprobetime=$(date -d "$nprobeDateTime" +%s)
#Get the diffirence between the systtem time and nprobe FIRST_SWITCHED
diff=$((systemt - nprobetime))
#Get the results - Results are measured in seconds
if (("$diff" <= 120))     #Change the OK time to your threshold
        then
                echo "OK - The times are $diff sec apart"
                exit 0
elif (("$diff" > 121)) && (("$diff" <=159)) #Change the WARNING time to your threshold - Between a period ie. currently between 121 sec & 159 sec
                then
                        echo "WARNING - Times are $diff sec apart"
                        exit 1
else
        if (("$diff" > 160))  #Change the CRITICAL time to your threshold - 1 above the last sec from WARNING
                then
                        echo "CRITICAL - Times are $diff sec apart"
                        exit 2
        fi
fi
Don't know if I'm missing anything
incorrect info
incorrect info
Re: Self created check - wrong info
For debugging purposes, can you have the result echo also systemt and nprobetime in the result so we can try to see where these numbers are coming from?
Then, run it over CLI and Nagios and post the results back.
