Dear Forum,
I have a requirement to setup monitoring using open source Nagios Core 4.1.1 for the following components. I would like to know if there are any dependency that I need to be aware of for each of these
SunOS 5.10 (Does the client/plugins/agent can be installed as is or each of them need to be a single SysV package?)
Weblogic 12c (Can the same wlsagent be used for JMX monitoring as well?)
iPlanet (Does it have a supported plugin)
SOAP/REST/MQ (Do we have Nagios Core supported plugins for these interfaces and which metrics do they cover)
HBASE (Do we have a supported plugin?)
Please mention anything else that I should be aware of for this implementation. Thanks
Regards,
Sundar
Nagios Core 4.1.1 set-up
Re: Nagios Core 4.1.1 set-up
You have already posted an almost identical question here:
https://support.nagios.com/forum/viewto ... 24#p162824
I will be closing this post now, and you can continue in the original. Please only open one forum thread per issue.
