Just a quick question. I'm running Nagios XI 2014R2.7 and I wasn't sure if there was a better way to create alerts for traffic patterns.
Currently I've created a baseline of what my normal limits should be, then set that as my alert threshold for my router interfaces. However what I'm looking for is something similar to what I have in observium, except that I can alert on.
For instance Observium will overlay a bandwidth line based on trends and previous periods. I'd like to do something similar except create an alert if the current bandwidth exceeds that value [ x > ( n * 2.25) ] for example that would take the normalized value of n and increase it by 225%. if the current bandwidth exceeds this for a period of time, then alert.
I know it sounds complicated, but I know it's possible. I've used Andrisoft Wanguard previously which does the same thing to detect incoming DDoS floods and then shunts the traffic through a filter when it happens.
Thanks everyone!
Traffic Pattern Monitoring
Re: Traffic Pattern Monitoring
I don't think there is a way to achieve this functionality in XI, let me reach out to the devs and I'll let you know what they say.
