nagios pluggin using bash script
venkitesh
Post by venkitesh »
Hi Team,
i am writing a bash script to monitor netapp volumes which are greater than 90%
#!/bin/bash
OK=0
CRITICAL=2
sshpass -p 'test_user' ssh -o StrictHostKeyChecking=no -l test_user 10.0.01 'volume show -percent-used > 90%' |awk '{print $2,$6,$7,$8}' | column -t  >> strcritical
cat strcritical;
if [[ `cat strcritical` == *"your"* ]]
then
echo "OK"
exit $OK
rm -rf strcritical;
else
echo "CRITICAL"
rm -rf strcritical;
exit $CRITICAL;
fi
the ouput is getting as expected.
But even though i have given the exit codes for critical and ok in the script, nagiosxi is not understanding that.
When i am integating this with nagios xi, it is not changing the service state. Seems like some syntax issue.
Could you please how to change the above script make it work.
Regards
Venk
Reason: Please use [code][/code] tags around long output
Re: nagios pluggin using bash script
Two things. First, remove the cat strcritical; line as that will pollute your status output.
Second, you likely will want to switch these two lines:
exit $OK
rm -rf strcritical;
to this
exit $OK
rm -rf strcritical;
otherwise your script is exiting before it can clean up the strcritical file. You might also consider using > instead of >> for the output saving, unless you need to keep the history in that file.
venkitesh
Post by venkitesh »
hi team,
Thanks it worked!!
i am getting an error message in my nagios xi server
nagios: Warning: Service performance data file processing command '/bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/xidpe/1454046093.perfdata.service' timed out after 5 seconds
Please help
Regards
Venkitesh
What happens if you increase your perfdata_timeout=5 to 20 in your nagios.cfg?
After that, restart your nagios service. Let us know if that works.
