We've had a request to monitor if a process has not run on a windows server in more than 1 day.
For example, we have an automate process that runs every day at 5 am. A few times in the past, some glitch has caused the process to be hung and not run the following morning at 5 am. Is it possible to interrogate the run status of a process and alert if it is hung or over the limit or otherwise not active for greater than a specified period?
Does anyone know how we could do that or an existing plugin that does this? I've done some looking but have yet to find anything.
thanks!
Penny Karr | IT Infrastructure Monitoring
Harvard Vanguard Medical Associates, an Affiliate of Atrius Health
254 Second Avenue | Needham, MA 02494
P (781) 292-1853 | F (781 292-1980 | http://www.harvardvanguard.org
Email: [email protected]
windows process hasn't run in x amount of time
- Box293
- Too Basu
Re: windows process hasn't run in x amount of time
Any approach requires you to track the last time the process was run, usually to log it in a file or something.
The easiest way to do this is to make your automated process create a simple text file in C:\Temp\ with some content like "I ran".
You can then use NSClient++ to check if this file is older than XXX:
Command:
Output when files matching criteria are found:
OK: All 1 files are ok|'count'=1;0;1
Output when NO files matching criteria are found:
No files found|'count'=0;0;1
I have a bunch of file related checks here:
http://sites.box293.com/nagios/guides/c ... es-folders
Does this help?
Command:
check_nrpe -H 192.168.142.1 -t 30 -c check_files -a path='C:\\Temp\\test_file.txt' 'filter=written > -24h' 'critical=count<1' 'empty-state=critical'OK: All 1 files are ok|'count'=1;0;1
Does this help?
