Data not graphing
CFT6Server
Data not graphing
Post by CFT6Server »
I notice that a device doing CPUload check was not graphing the 5m and 15m load data. But the results does include the 5m and 15m perf data.
Using check_linux_cpuload.pl:
Result in Advanced under XI confirming data: Performance Data: Load1m=0.64 Load5m=0.68 Load15m=0.70
Using Box293 Performance Tool to confirm that only 1m is graphing
running the command:
 ./check_linux_cpuload.pl -H server-C public-s 2 -w 80 -c 90
CPU Load OK - No Problems found (Average Load 0.79)|Load1m=0.81 Load5m=0.80 Load15m=0.77
Not sure why this is happening. Anyway to savage this without removing and readding the service check?
Re: Data not graphing
Where did you get the script from, check_linux_cpuload.pl? Can you post it here for us to take a look at?
Post by Box293 »
Also, can you go to the Advanced tab of that service and show us a screenshot please.
CFT6Server
This was modified by us to provide CPU load. I have it running for few hundred devices but I only found this particular one to be an issue.
Attached are the screenshots.
Here's a sample of a good one
CFT6Server
Here's the check linux cpuload file.
Post by Box293 »
The performance data the script is outputting looks formatted correctly.
Lets increase the logging verbosity and then take a deeper look into the logs. Follow the FAQ entry below to increase the log level of process_perfdata and npcd:
http://support.nagios.com/wiki/index.ph ... leshooting
Wait 15 - 20 minutes and then get a tail of the logs:
tail -250 /usr/local/nagios/var/perfdata.log > /tmp/perfdata.txt
tail -250 /usr/local/nagios/var/npcd.log > /tmp/npcd.txt
Send us a copy of /tmp/perfdata.txt and /tmp/npcd.txt
Don't forget to turn down the log level as per the FAQ when you are done!
I'm positive there will be errors about more data sources than what exists in the RRD file, these steps will fix it:
ICMP and Ping Checks Stopped Graphing After XI 2014 Upgrade
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
