Repeated alerts for users migrated from Nagios Core
I have a number of hosts, services and contacts from Nagios Core, recently I migrated them to Nagios Core 5.
Originally it was using "notify-host(service)-by-email" to send email alert, after migration we created users linking with the contacts, and use "xi_host(service)_event_handler" for alerting. Now once there is any alert, users got 2 emails, one sending from xi_host_event_handler and one sending from notify-host-by-email, why does this happen? I can't find anything wrong in configuration indeed.
Re: Repeated alerts for users migrated from Nagios Core
Are you using sendmail or SMTP?
Can you post the service definition of one for us to take a look at?
Using sendmail locally.
Basically we only see "notify-host-by-email" in template "generic-contact".
But the user getting repeated email is using template "xi_contact_generic" and he actually receiving email one by "notifiy-host-by-email" and one by "xi-host-notification-handler".
Here are an example of the service and contact we are getting double alerts.
define contact {
name generic-contact
host_notification_period 24x7
service_notification_period 24x7
host_notification_options d,r,f,s
service_notification_options w,c,r,f,s
host_notification_commands notify-host-by-email
service_notification_commands notify-service-by-email
register 0
service_description PING
use generic-net-service
hostgroup_name SHHO
check_command check_ping!200.0,20%!600.0,60%
check_interval 5
retry_interval 1
register 1
name generic-net-service
is_volatile 0
max_check_attempts 3
check_interval 5
retry_interval 2
active_checks_enabled 1
passive_checks_enabled 1
check_period 24x7
parallelize_check 1
obsess_over_service 1
check_freshness 0
event_handler_enabled 1
flap_detection_enabled 1
process_perf_data 1
retain_status_information 1
notification_interval 30
notification_options c,r,
notifications_enabled 1
contact_groups network
register 0
define contactgroup {
contactgroup_name network
alias network Administrators
contactgroup_members xi_testing_group
contactgroup_name xi_testing_group
alias Control Tier Group
members hyleung
define contact {
contact_name hyleung
alias hyeung
host_notification_period hyleung_notification_times
service_notification_period hyleung_notification_times
host_notification_options d,u,r,f,s
service_notification_options w,u,c,r,f,s
email [email address removed]
use xi_contact_generic
define contact {
name xi_contact_generic
contactgroups xi_contactgroup_all
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period xi_timeperiod_24x7
service_notification_period xi_timeperiod_24x7
host_notification_options d,u,r,f,s,
service_notification_options w,u,c,r,f,s,
host_notification_commands xi_host_notification_handler
service_notification_commands xi_service_notification_handler
can_submit_commands 1
register 0
Do you have an 'XI User' with the same name as the 'Contact'?
This is a good document to take a look at:
https://assets.nagios.com/downloads/nag ... ntacts.pdf
Former Nagios Employee.
me.
me.
Yes, we have created them according to the document.
- Box293
- Too Basu
Taking a step back for a second.
Can you paste the contents of the duplicate alerts here so we can compare them please.
Also what is the output of these commands:
If it's the ping service you are receiving multiple emails for, is it possible you are receiving one email for the HOST object (which happens to be a ping check) and a SEPARATE email for the Ping service?faiwong wrote: But the user getting repeated email is using template "xi_contact_generic" and he actually receiving email one by "notifiy-host-by-email" and one by "xi-host-notification-handler".
Here are an example of the service and contact we are getting double alerts.Code: Select all
define service { service_description PING use generic-net-service hostgroup_name SHHO check_command check_ping!200.0,20%!600.0,60% check_interval 5 retry_interval 1 register 1 }
ipcs -q
ps -ef | grep nagios.cfgAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Both of the alerts are "host" alert, and they are about 2 minutes apart.
When the host was down, 1st alert received, 2nd alert (repeated) came around 2 minutes later, after the notification interval, 2 alerts again, until the host is back online.
So in our opinion it is something duplicated. But it was OK for Nagios XI users newly created (not imported from core).
[nagios@nagiosxi cfgprep]$ ipcs -q
------ Message Queues --------
key msqid owner perms used-bytes messages
0xf4000002 196608 nagios 600 0 0
[nagios@nagiosxi cfgprep]$ ps -ef | grep nagios.cfg
nagios 16052 1 3 11:38 ? 00:00:04 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 16415 16052 0 11:39 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 22083 8996 0 11:40 pts/0 00:00:00 grep nagios.cfg
- Box293
- Too Basu
Do you have paid support?
This is something that will be much easier to resolve through a support ticket.
If you do, please send an email to [email protected] referencing this forum thread and we'll take it from there. Reply to this thread when you have done this so we can confirm we received the email.
Otherwise you'll need to make a copy of your profile available to us and then email that url to the support user in this forum:
https://support.nagios.com/forum/member ... le&u=62610
Click the Admin menu
System Config > System Profile
Click the Download Profile button and send us that file
No problem, we just bought the paid support last week.
Please submit a support ticket in, and let us know once this is done.
As of now, I don't see a ticket open currently for this. Did you email [email protected]?
