E-mail as Input
comfone
E-mail as Input
Post by comfone »
Hi all
We have many "services/tasks" sending e-mail as notification.
How could I feed them into NLS?
Did someone try that already?
Thank you in advance for your feedback.
jolson
Attack Rabbit
Re: E-mail as Input
Post by jolson »
There is an input designed for exactly this purpose. You can read about this input at the following location:
https://www.elastic.co/guide/en/logstas ... -imap.html
Note that your mail system must support IMAP for the above plugin to work properly. You can define a new input on the 'Administration -> Global Configuration' page of Nagios Log Server.
Required options:
imap {
    host => ...
    password => ...
    user => ...
After defining the new input, run an 'Apply Configuration' - this input will periodically check on that mailbox and import any new information.
Thanks!
Twits Blog
comfone
Re: E-mail as Input
Post by comfone »
Thank you for your feedback.
